CFD Validation - estimating iteration error
Old   November 20, 2019, 07:44
Default CFD Validation - estimating iteration error
Oliver Glahn
oliver.glahn is on a distinguished road
does anyone else uses the Ferziger method to evaluate the iteration error?
I wanted to use the method described in „FURTHER DISCUSSION OF NUMERICAL ERRORS IN CFD“ from 1996 to quantify my iteration error based on target values.
See the attached image of the formula for the part of linear convergence.
I find it very difficult working with it and interpreting the error.
If my solution is about to converge and the difference between the iterations decrease, my eigenvalue (calculated as shown in the image) tends to be <1 but very close to 1. This would result a negative and very small denominator for the error calculation.
Therefore I am wondering in what circumstances it could be used, or if I have an interpretation mistake.
Furthermore I am wondering what are the recommended ranges of such calculated error and why is it related to the eigenvalue based on iteration differences instead the absolute value, as we usually do for relative errors?
Does anyone know how to work and interpret the results of such method?
Thank you very much
Oliver
oliver.glahn is offline   Reply With Quote
cfd validation, iteration error
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
