Prashant
Rep Power: 7 ![]() |
I've created Ahmed body and plotted the velocity profile. I've tried to compare it with experimental data, all the way values are almost the same but My problem is that at the beginning position it shows negative value in experimental data but I'm not getting the negative value. As at -163mm, as in the given image below with blue tick mark, there are some negative values at the beginning near-wall but mine are not. I think I'm getting absolute value, does anyone know how to correct them. Ex perimental data is from.http://cfd.mace.manchester.ac.uk/cgi...as82_rsol.html |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
You're plotting and tabulating velocity magnitude.... which is a positive semi-definite quantity.... Yes, it's like an absolute value. Maybe plot something else...
Prashant
But my aim is to create velocity profile of Ahmed body as shown in experimental data,
Can you please tell me what is the best way to create velocity profile to get negative value with it also? |
ahmed body, post procesing, star ccm, star ccm+, star ccm+ help |
Panel-Method, velocity calculation | mrbm | Main CFD Forum | 17 | August 5, 2022 11:03 |
serial udf to parallel udf | radioss | Fluent UDF and Scheme Programming | 10 | January 19, 2019 08:56 |
Ahmed Body Simulation | nick | FLUENT | 5 | December 24, 2018 11:13 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Drag over Ahmed body | Shamoon Jamshed | FLUENT | 2 | May 18, 2009 14:15 |
