Inviscid solution gives different results for Constant Density and Incompressible |
October 31, 2019, 16:41 |
Jimmy
Rep Power: 15 |
I'm running Fluent on a very low speed (M~0.05) 3D airplane model using the inviscid mode.
For Materials, I tried both Constant Density (rho = 1.225kg/cu.m) and Incompressible-Ideal-Gas (Po = 101325Pa, MW=28.966kg/kmol, T0=288.15K, so it should give a density of approximately 1.225). However, with Constant Density, I'm getting a CL of 1.22, which is very close to the VLM result; with Incompressible-Ideal-Gas, I'm getting 1.4. The pitching moment is also sufficiently different. Why the big difference in results? Note that since it's running inviscid solution, the mesh is all tetra and has no prism layer. |
Inviscid solution gives different results for Constant Density and Incompressible | wildabyss | FLUENT | 0 | October 30, 2019 22:18 |
Ahmed body simulation gives unexpected results in su2 6.0 | anas651 | SU2 | 0 | March 28, 2018 04:42 |
Continuing incompressible results with compressible solver | linkamp | OpenFOAM Running, Solving & CFD | 0 | July 22, 2016 09:54 |
(incompressible) interFoam - where is the density in the k, epsilon and continuity eq | idefix | OpenFOAM | 0 | December 22, 2015 15:40 |
Help : Algorithm for incompressible variable density flows | Meeranandan | Main CFD Forum | 0 | February 6, 2013 07:55 |
