wmake new solver error
Old   October 24, 2019, 14:58
Exclamation wmake new solver error
pjagdale1's Avatar
Pradeepkumar Jagdale
pjagdale1 is on a distinguished road
Please, can someone help me with this error? I am trying to compile my own new solver but "wmake" command gives the following error. (in foamextend 4.0)
pradeep@pradeep-HP-Pavilion-15-Notebook-PC:~/foam/pradeep-4.0/applications/solvers/passiveScalaricoFoam$ wmake
SOURCE=passiveScalaricoFoam.c ;  gcc -m64 -Dlinux64 -DWM_DP -Wall -O3  -I/home/pradeep/foam/foam-extend-4.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/pradeep/foam/foam-extend-4.0/src/foam/lnInclude -I/home/pradeep/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/passiveScalaricoFoam.o
In file included from /home/pradeep/foam/foam-extend-4.0/src/foam/lnInclude/labelList.H:35:0,
                 from /home/pradeep/foam/foam-extend-4.0/src/foam/lnInclude/Pstream.H:43,
                 from /home/pradeep/foam/foam-extend-4.0/src/foam/lnInclude/OPstream.H:35,
                 from /home/pradeep/foam/foam-extend-4.0/src/foam/lnInclude/parRun.H:35,
                 from /home/pradeep/foam/foam-extend-4.0/src/finiteVolume/lnInclude/fvCFD.H:4,
                 from passiveScalaricoFoam.c:36:
/home/pradeep/foam/foam-extend-4.0/src/foam/lnInclude/label.H:38:19: fatal error: climits: No such file or directory
compilation terminated.
passiveScalaricoFoam.dep:713: recipe for target 'Make/linux64GccDPOpt/passiveScalaricoFoam.o' failed
Thank you
pjagdale1 is offline   Reply With Quote
climit, error, solver compilation error, wmake
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 05:41
