A simple question about time step with wind turbine simulation |
October 17, 2019, 19:59 |
João de Sousa Bomfim Neto
Rep Power: 9 |
Hy ladies and gentlemen,
I have simulated a VAWT with sliding mesh Technic, constant free stream wind velocity and, to change TSR, the angular velocity is modified. My question is: When I change angular velocity I should to maintain time step value or I should fix the angular step (Delta theta) for the others TSRs points? Have a great day! |
October 18, 2019, 03:52 |
Carlo_P
Rep Power: 8 |
In theory, you have to change the time step,
As always, if you can use a smaller time step would be better. Can you have an idea of your Courant Number? It would be better to have it smaller then 20-50. It depends of the solver. Cheers! |
October 18, 2019, 09:56 |
Rep Power: 9 |
Hy Carlo, thanks for you answer. My higher Courant number is about 250, but I previously did a time step study for the one TSR point, and this give me a time step equal to 6e-04 s, equivalent to 2 degree per times step. A value under this don't show a significant difference. So, I did this thread to know if should I use 2 degree per time step or use 6e-04 s per time step. Grateful for your attention!!!
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 06:49 |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 08:09 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 11:08 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
