modelling foam formation
Old   October 10, 2019, 02:23
Default modelling foam formation
Michael
drmazi is on a distinguished road
Hi, i am modelling the formation of foam from vertically falling water jet containing dissolved surfactant falling unto a water surface resulting in formation of foam. I have been able to simulate falling water jet in Fluent but I do not know how to go about simulating the formation of foam bubbles. I need your suggestion and input.
drmazi is offline   Reply With Quote
Old   October 10, 2019, 03:51
Arjun
arjun will become famous soon enougharjun will become famous soon enough
it is little difficult to advise without really knowing how the foam is formed.
If the foam is simply a liquid with air trapped inside it then it is just shown by area where volume fraction is between 0 to 1.
Or foam is result of a chemical reaction resulting in a phase that has porosity then it is very tough to do with fluent. This video is where foam is generated due to chemical reaction:
https://youtu.be/9kkBMeEl2R8
arjun is offline   Reply With Quote
Old   October 10, 2019, 09:44
BlnPhoenix is on a distinguished road
Just my to cents, open for correction and discussion:
To my knowledge this has not been done so far in realistic way using a VOF approach. The hindered Colescence is hard to implement, since on a microscopic level coalescence is only desribed accurately when you consider all the (inter-bubble-)forces acting on the bubbles that make up the foam (DLVO theory, zeta potential etc)...VOF usally tends to overpredict coalescence rates because these forces are not accounted for, so that in a VOF simulation no Foam will ever build up.
What you can work around is something like Arjun mendtioned, a third phase with certain properties that represents your foam on a macroscopic level in an Euler-Euler-type of simulation..
BlnPhoenix is offline   Reply With Quote
Old   October 10, 2019, 13:12
Michael
Yes, I know it a little difficult but the foam is formed as a result of air entrainment of the falling liquid which contains dissolved liquid soap.
There is no reaction involved. The foam is formed on the surface of the free water. I have conducted experiment to understand the physics and in my fluent simulation, I could only model bubble formation using Multiphase VOF.
Old   October 10, 2019, 13:22
Michael
You are right. It has not been done. I am thinking if I could create a third phase specifying the liquid soap. But another consideration is that the falling jet falls onto a rectangular vessel of dimension 50cm x 30cm x 80 cm (length X width X height). The rectangular tank contains free water of height 10cm while the falling jet contains dissolved liquid soap.
Just seeking suggestions and advice. I have simulated using Multiphase VOF patching after initialization to account for the free water level.
My concern is how to specify the falling water jet to represent the dissolved liquid soap or incorporate it using UDF of empirical relation of foam height with time obtained from my experiment.
Old   October 11, 2019, 03:29
About your concern: I would create an inlet on top of the tank, that releases the jet towards the surface. You can use a time depended inlet value for velocity to constrain the jet entering to a fixed time period.
Old   October 13, 2019, 11:22
Michael
From my inquest, I think it is not possible to obtain chemical formula for Sodium Lauryl Sulfate in Fluent.
My thought is how to possibly include the experiment foam height variation with time using udf.
Old   October 14, 2019, 05:44
With classical VOF approach you will not suceed imo. You will need to implement a pseudo force for each bubble acting as hinderance for bubble coalescence resulting in foam formation. Good luck
Old   October 14, 2019, 09:46
Arjun
The way this simulation could be done is that one can run with 2 phase VOF simulation while third phase (foam) is generated as some model (or based on condition). One can solve simple scalar transport for this third phase with its generation controlled by VOF model.
Old   October 14, 2019, 23:32
Michael
If h = 0.0048ln(t) + 0.0107 represent the empirical model for the foam height, please how do i implement and solve for third phase (foam). I am new to handling this.
Thanks
Old   October 16, 2019, 10:13
Thanks
You can create a mass source term for concentration of the third phase.
Old   October 16, 2019, 11:37
Arjun
Thanks
This is not really helpful.
What you are saying is that height is function of time. If this is exactly what you want then you can probably just overwrite the volume fraction to 1 based on this function. It gives you what you want for this 1 set up.
Old   October 17, 2019, 02:46
Michael
What I mean is the height of free water is fixed but as the water jet falls onto the free surface due to reduction in surface tension and air entrainment, foam gradually forms and the height of foam varies with time.
Old   October 21, 2019, 07:30
The Problem with your equation, which should be fairly easy to implement into a mass source term, is that you only create foam and it will not be destroyed with time. In reality foam will eventually vanish, will it not?
Old   October 22, 2019, 04:10
Michael
it takes very long time to varnish. At first creating foam is essential but very dense foam takes long time to varnish.
Old   October 22, 2019, 04:27
Ok. Than to accomplish this write a Mass/Volume Fraction source term that creates an amount of volume of that "foam" phase according to your equation. Heigth of foam phase translates to a total amount of volume depending on your container geometry. This is straightfoward and easy to implement.
You may need an additional "sink term" to account for reduced volume of your other two phases during "foam" build up.
Old   December 2, 2023, 02:12
Nopel
Vasa is on a distinguished road
does the viscosity increase? Can you provide a tutorial for making it? in my results the viscosity decreases below the viscosity of water, I really need information for my final college assignment
Vasa is offline   Reply With Quote
Old   December 2, 2023, 04:01
Joern Beilke
JBeilke is on a distinguished road
There is a nice work of Petr Karnakov and Sergey Litvinov on this topic. They also released their solver :-)
https://github.com/cselab/aphros
https://www.youtube.com/watch?v=iGdphpztCJQ
https://www.youtube.com/watch?v=0Cj8pPYNJGY
JBeilke is offline   Reply With Quote
Old   December 3, 2023, 23:38
Nopel
I'm still confused, whether in the Ansys fluent simulation foam formation with the VOF model can increase viscosity?
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." lethu OpenFOAM Meshing & Mesh Conversion 1 June 3, 2020 08:49
Derivative of velocity and mean velocity hiuluom OpenFOAM Post-Processing 1 May 30, 2015 00:42
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
Foam formation during flow ghadab Main CFD Forum 2 January 30, 2013 07:59
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
