Turbulent Dissipation Rate Concept (epsilon)
Old   October 9, 2019, 14:20
Default Turbulent Dissipation Rate Concept (epsilon)
E. Lowry
elowfoam is on a distinguished road
I am struggling to understand conceptually how to handle the turbulent dissipation rate (epsilon), for example in the k-epsilon RANS framework. I understand that epsilon is a calculated value per element, however in engineering design, it is often useful to know the total turbulent dissipation rate for a single device (e.g. static mixer).
In order to get the total turbulent dissipation rate from CFD for an entire static mixer, can I take an average of epsilon (m2/s2) over the entire region of fluid surrounding the device? It should not be a delta correct? Perhaps I am thinking about epsilon in the wrong way. Any advice would be appreciated.
Thanks!
elowfoam is offline   Reply With Quote
Old   October 9, 2019, 15:25
Lucky
You just integrate it over the volume (i.e. summation)
Old   October 9, 2019, 15:31
E. Lowry
Thank you!
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
Components of dissipation rate (epsilon) swtbkim Main CFD Forum 1 November 8, 2016 10:54
SSG Reynolds Stress Turbulent Source on Boundary st268 CFX 3 September 11, 2012 08:24
Turbulent dissipation rate effect turbine torque?? sedongjjang FLUENT 0 August 24, 2012 15:13
Turbulent Dissipation Rates - epsilon Otute Main CFD Forum 5 May 20, 1999 11:51
