October 8, 2019, 04:35 |
Xfoil question
Giuseppe
Hi everybody!
I'm using XFoil for some exercise and I had a question: Is there a way to get a flow field with all streamlines at a fixed Lift Coefficient on Xfoil?? If the answer is ''Yes'', could you tell me how to get it? Have a good day all of you! |
October 8, 2019, 09:46 |
Martijn
Rep Power: 10 |
I think this is not directly implemented.
However, what you can do is make a small script to compute the velocity at a certain points off the body using the VELS command. Note that this VELS command is not really accurate close to the boundary layer but for further off the body it can give a good estimation. |
Question about symmetry in Autodesk Cfd 2016 | ecto | Autodesk Simulation CFD | 0 | October 20, 2015 04:16 |
small question about the functionalities of topological changes in OpenFoam | ngj | OpenFOAM Running, Solving & CFD | 2 | February 28, 2013 10:02 |
Question Re Engineering Data Source | imnull | ANSYS | 0 | March 5, 2012 13:51 |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 15:26 |
Poisson Solver question | Suresh | Main CFD Forum | 3 | August 12, 2005 04:37 |
