September 22, 2019, 13:59 |
[SPH] SPlishSPlasH open-source codes
Rep Power: 8 |
Hi everybody,
Does anyone experience with Smoothed Particle Hydrodynamics (SPH)-based open-source codes, namely SPlisHSPlasH: http://www.interactive-graphics.de/index.php/downloads. I need to simulate a flow with SPH, but do not know how to get started with it. I cannot find a tutorial or simple test case. I really appreciate if someone can give me some useful tips to begin, or provide me a simple simulation with SPlisHPSPlasH so that I can imagine the general picture of code implementation. Thank you very much in advance. |
May 8, 2020, 08:54 |
#2 | |
Yage
Rep Power: 12 |
I got the same problem as yours, have you managed to get start with it? Currently, I just run the Cmake and make to build the code, and I found some example cases in the /data/scens files but how could I run them? Regards, yage |
May 9, 2020, 05:01 |
Rep Power: 8 |
Hi Yage,
Actually, I am stuck on modifying the codes. It would be nice if we can discuss and help each other. After running the codes, you can open a folder named 'bin', choose the solver (e.g., StaticBoundarySimulator or DynamicBoundarySimulator), and then point to one of the scenes. Regards, Cuong Bui |
open-source code, sph, splishsplash |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 04:50 |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 09:06 |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 11:03 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 14:59 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
