How to test maximum total pressure and maximum flowrate in centrifugal fan
Old   September 19, 2019, 23:11
Default How to test maximum total pressure and maximum flowrate in centrifugal fan
rj26 is on a distinguished road
Hello Everyone
I am carrying out a simulation of a centrifugal fan. I carried out simulation in normal operation conditions and CFD results showed good qualitative and quantitative agreement with experimental results.
My Boundary conditions are :
inlet: mass flow rate
outlet: static pressure
RPM: 1400
Flow rate : 1.44 kg/s
Fan type: Sirocco Fan
Number of the grid: 2.2 million
Turbulence model: SST
I want to test the fan for maximum total pressure and maximum flow rate condition but I am not sure how the boundary conditions are set are the following test case.
Please let me know what boundary conditions to use for testing :
1. Maximum total pressure condition
2. Maximum flow rate condition
Thank you
rj26 is offline   Reply With Quote
boundaries condition, fan analysis
Axial flow fan incorrect pressure rise yambanshee OpenFOAM Running, Solving & CFD 2 June 25, 2020 15:05
Calculating average total pressure over a surface Vinayak- FLUENT 2 May 16, 2018 02:02
Inlet and Outlet BC for maximum flow of a radial fan nash OpenFOAM Pre-Processing 0 October 24, 2013 04:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
