Modify a solver
Old   September 16, 2019, 10:28
Default Modify a solver
X
mcfdma is on a distinguished road
I have modified interFoam solver without making any changes within.
I have already had a look at https://openfoamwiki.net/index.php/H...ure_to_icoFoam and have been successful with the example.
I have changed the folder name
changed the .C file
changed the Make-files
XFoam.C
EXE = $(FOAM_USER_APPBIN)/XFoam
but I get an error when I compile
Making dependency list for source file XFoam.C
SOURCE=XFoam.C ;  g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam231/src/transportModels/twoPhaseMixture/lnInclude -I/opt/openfoam231/src/transportModels -I/opt/openfoam231/src/transportModels/incompressible/lnInclude -I/opt/openfoam231/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam231/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam231/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/opt/openfoam231/src/finiteVolume/lnInclude -I/opt/openfoam231/src/fvOptions/lnInclude -I/opt/openfoam231/src/meshTools/lnInclude -I/opt/openfoam231/src/sampling/lnInclude -IlnInclude -I. -I/opt/openfoam231/src/OpenFOAM/lnInclude -I/opt/openfoam231/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linuxGccDPOpt/XFoam.o
In file included from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcDiv.C:29:0,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcDiv.H:180,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcDDt.C:27,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcDDt.H:76,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvc.H:45,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvCFD.H:8,
                 from XFoam.C:40:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/divScheme.H: In constructor ‘Foam::fv::divScheme<Type>::divScheme(const Foam::fvMesh&)’:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/divScheme.H:111:32: error: expected type-specifier before ‘linear’
             tinterpScheme_(new linear<Type>(mesh))
In file included from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcGrad.C:29:0,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcGrad.H:124,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvc.H:49,
                 from XFoam.C:40:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/gaussGrad.H: In constructor ‘Foam::fv::gaussGrad<Type>::gaussGrad(const Foam::fvMesh&)’:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/gaussGrad.H:88:32: error: expected type-specifier before ‘linear’
/opt/openfoam231/src/transportModels/incompressible/lnInclude/gaussGrad.H: In constructor ‘Foam::fv::gaussGrad<Type>::gaussGrad(const Foam::fvMesh&, Foam::Istream&)’:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/gaussGrad.H:101:21: error: expected primary-expression before ‘(’ token
/opt/openfoam231/src/transportModels/incompressible/lnInclude/gaussGrad.H:102:29: error: expected type-specifier before ‘linear’
In file included from /opt/openfoam231/src/transportModels/incompressible/lnInclude/correctedSnGrad.H:150:0,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/laplacianScheme.H:42,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcLaplacian.C:28,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcLaplacian.H:242,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvc.H:53,
                 from XFoam.C:40:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/correctedSnGrad.C: In member function ‘Foam::tmp<Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::fv::correctedSnGrad<Type>::fullGradCorrection(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) const’:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/correctedSnGrad.C:54:9: error: ‘linear’ was not declared in this scope
       & linear<typename outerProduct<vector, Type>::type>(mesh).interpolate
/opt/openfoam231/src/transportModels/incompressible/lnInclude/correctedSnGrad.C:54:9: note: suggested alternative:
In file included from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcAverage.C:29:0,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcAverage.H:91,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvc.H:42,
                 from XFoam.C:40:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/linear.H:52:7: note:   ‘Foam::compressibilityModels::linear’
 class linear
                 from XFoam.C:40:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/correctedSnGrad.C:54:57: error: expected ‘(’ before ‘>’ token
/opt/openfoam231/src/transportModels/incompressible/lnInclude/correctedSnGrad.C:54:65: error: ‘const class Foam::fvMesh’ has no member named ‘interpolate’
In file included from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcLaplacian.C:28:0,
                 from XFoam.C:40:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/laplacianScheme.H: In constructor ‘Foam::fv::laplacianScheme<Type, GType>::laplacianScheme(const Foam::fvMesh&)’:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/laplacianScheme.H:113:37: error: expected type-specifier before ‘linear’
             tinterpGammaScheme_(new linear<GType>(mesh)),
In file included from createFields.H:29:0,
                 from XFoam.C:60:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/createPhi.H: In function ‘int main(int, char**)’:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/createPhi.H:49:24: error: ‘linearInterpolate’ was not declared in this scope
     linearInterpolate(U) & mesh.Sf()
In file included from XFoam.C:60:0:
createFields.H:74:13: error: ‘incompressible’ was not declared in this scope
     autoPtr<incompressible::turbulenceModel> turbulence
createFields.H:74:44: error: template argument 1 is invalid
createFields.H:75:5: error: invalid type in declaration before ‘(’ token
createFields.H:76:9: error: ‘incompressible’ is not a class or namespace
         incompressible::turbulenceModel::New(U, phi, mixture)
In file included from XFoam.C:64:0:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/CourantNo.H:51:1: error: ‘namespace’ definition is not allowed here
 namespace Foam
In file included from XFoam.C:65:0:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/setInitialDeltaT.H:35:40: error: ‘CoNum’ was not declared in this scope
     if ((runTime.timeIndex() == 0) && (CoNum > SMALL))
In file included from XFoam.C:76:0:
setDeltaT.H:37:20: error: ‘CoNum’ was not declared in this scope
         min(maxCo/(CoNum + SMALL), maxAlphaCo/(alphaCoNum + SMALL));
In file included from XFoam.C:90:0:
UEqn.H:5:19: error: base operand of ‘->’ is not a pointer
       + turbulence->divDevRhoReff(rho, U)
XFoam.C:100:27: error: base operand of ‘->’ is not a pointer
                 turbulence->correct();
In file included from XFoam.C:61:0:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/readTimeControls.H:38:8: warning: unused variable ‘maxDeltaT’ [-Wunused-variable]
 scalar maxDeltaT =
make: *** [Make/linuxGccDPOpt/XFoam.o] Error 1
Where am I going wrong?
mcfdma is offline   Reply With Quote
Old   September 16, 2019, 12:39
agd
agd is on a distinguished road
My first guess would be don't use a space in a file name in linux. Rather than "new linear", try "new_linear".
agd is offline   Reply With Quote
Old   September 16, 2019, 13:03
X
My folder name doesnt have any space (changed from interFoam to XFoam)
Old   September 16, 2019, 14:32
agd
Somewhere the compiler is seeing "new linear" and bombing on that. Because there is white space between those words the compiler sees it as a name and a modifier. I am not familiar with openFoam or any of its derivatives, but your compiler problem seems to be that "new linear" doesn't need to appear as two words. Find that and you'll probably fix your problem.
solver compilation error
Modify Particle Velocity in Lagrangian Solver AustinG OpenFOAM 0 August 23, 2018 18:38
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
CFX solver workspace properties: modify default values zboud CFX 2 March 8, 2010 09:10
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
To modify the interFoam solver for cavitating zjucfd OpenFOAM Running, Solving & CFD 5 August 26, 2007 09:03
