Shell & Tube simulations-pressure loss oscillation |
September 8, 2019, 10:57 |
Majid Zarif
Rep Power: 12 |
Hi
I modeled a shell and tube heat exchanger in Ansys fluent and with B.Cs of 1- Constant inlet mass flow rate of water(Mass Flow Inlet) 2-Tube temperature is constant(Wall-Temperature) 3-outlet flow is zero pressure gradient (Pressure outlet) 4- Re number of 10000,15000 & 20000 5-Turbolancy model : K-Omega SST the outlet flow temperature is properly converged but the pressure loss results don't converge and oscillates. I also tried to vary the mesh number from 400k to 2milion but it didn't effect. Would you please give me suggestions to solve this problem? I attached the geometry and one of pressure loss plots pictures. Regards pressure plot3.jpg geometry.png |
CFX Solver stopped with error when requested for backup during solver running | Mfaizan | CFX | 40 | May 13, 2016 07:50 |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 14:04 |
Outlet pressure | aja1345 | FLUENT | 5 | August 18, 2015 12:02 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 17:29 |
Pressure in impedance tube | nnis09 | Fluent Multiphase | 0 | March 27, 2014 04:35 |
