Inverse engineering coefficients Ogden model
Old   September 4, 2019, 22:31
Default Inverse engineering coefficients Ogden model
SteFanI is on a distinguished road
Hello
I have a series of load and displacement values data from instron machine on a viscohyperelastic material (polyvinylchloride).
I am going to use the 1st order Ogden model to simulate this material in ANSYS Finite Element.
There is a way to use those data that I got from Instron Stress/Tensile machine (load,displacement) in order to inverse engineer the mu and alpha nonlinear coefficients of the ogden model (1st order) and predict the forces that cause the strain on the material along the width of its surfaces.
I don't know the procedure of how to do this in ANSYS. Any kind of help would be appreciated. Thank you very much.
Kind Regards
SteFanI is offline   Reply With Quote
curve fit, hyperelastic, ogden, reverse engineering
Modifying Turbulence Model Coefficients dsh5400 OpenFOAM Pre-Processing 5 September 1, 2016 04:44
about Subgrid-scale model impecca OpenFOAM Running, Solving & CFD 4 December 20, 2013 11:36
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
K - epsilon VS SST turbulence model Maicol Main CFD Forum 0 November 30, 2012 17:25
Workbench engineering data model zegtuhetmaar ANSYS 0 February 9, 2010 07:55
