3D airfoil shape generation using Fortran or C++ ?
Old   September 2, 2019, 12:55
Default 3D airfoil shape generation using Fortran or C++ ?
JOYOUS is on a distinguished road
Currently i am doing wind turbine blade optimization by coupling CFD solver and genetic algorithm . For 2D shape parmeterization, i have used PARSEC parmeterization and was able to generate airfoil shape and it works.
Now i want to extend my work in to 3D . Anyone who can give me a direction/references how i am going do it ? or how can i convert my 2D airfoil shape generated data in to 3D ?
Thanks !!
JOYOUS is offline   Reply With Quote
Old   September 3, 2019, 17:43
Matt
fluid23 is on a distinguished road
Aren't wind turbine blades just a loft between 2D sections? Getting a 3D geometry from a series of 2D sections defined along the span should be straight forward.
Most wind engineering books have good discussions on blade optimization in the context of blade element momentum theory. If you have a way to optimize your 2D profile then coupling that with a BEM solver to maximize your efficiency is pretty straight forward. Just be aware of the Betz limit and you should be fine.
fluid23 is offline   Reply With Quote
Old   September 4, 2019, 09:14
Thanks for your reply.
Actually i have used direct forcing immersed boundary method for solver which is FVM based solver. i want some reference/guideline to develop code span wise surface to get 3D geometry from 2D section.
Thanks once again.
Airfoil Generation & making grid over it. R.V.Ramkumar Main CFD Forum 2 November 2, 2015 11:22
2D FFD Optimization RLangtry SU2 2 August 5, 2014 10:48
grid generation and transferring it into Fortran code HaKu Main CFD Forum 1 April 28, 2011 03:11
Grid generation code in Fortran artemiss1984 Main CFD Forum 3 February 23, 2011 02:19
Latest news in mesh generation Robert Schneiders Main CFD Forum 0 March 2, 1999 05:07
