August 15, 2019, 16:51 |
Geometry
Rep Power: 7 |
Hi CFD- Online
I want to make a CFD analysis of a heat exchanger. It's a quite complex geometry, so for the sake of drawing, it would be easiest to just draw the solid parts ie. wall of the shell and tubes respectively. Is that enough? Can the programs (OPENFOAM and ANSYS) make the fluid domain by itself? Or do I need to draw all of it ? Hoping some one can clear this. BR |
ansys, fluid domain, geometry generation, openfoam 1.7.x |
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE | mariachi | ANSYS Meshing & Geometry | 5 | May 30, 2018 02:52 |
Question about Geometry vs. Meshes | EphemeralMemory | ANSYS Meshing & Geometry | 2 | December 8, 2016 13:02 |
How to scale and translate the grid of particle data and STL geometry | Saidul | Tecplot | 1 | January 11, 2015 21:15 |
Running CFD parallel. There is no geometry file! | CrashLaker | SU2 | 6 | April 10, 2014 03:08 |
[CAD formats] translating geometry from Abaqus to OpenFOAM | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | January 10, 2014 13:49 |
