FSI of flow through pipe
Old   August 13, 2019, 06:02
Post FSI of flow through pipe
thedal's Avatar
Thamilmani M
thedal is on a distinguished road
Hello everyone,
My problem involves, flow of water heated through a pipe which is heated by constant heatflux on the sides of the pipe and I need to check the thermal stress and deformation because of the temperature profile caused by the flow.
I have simulated the 3D steady fluent simulation of inlet velocity and temperature, outlet pressure and temperature. sides of the pipe are no-slip wall and constant heat flux.
Now I don't know how to couple the fluid solution to ANSYS Structural to get the deformation of the pipe.
Thank you
Always
Thedal
thedal is offline   Reply With Quote
ansys, cfd, fsi, pipeflow, structural
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 22:25
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 12, 2012 00:18
[ASK] Flow in Corrugated Pipe with FLUENT Primadhani FLUENT 1 May 11, 2011 21:41
Pipe Flow Saima CFX 1 January 10, 2011 17:41
