Ansys Coupling Analysis
Old   July 26, 2019, 04:15
Default Ansys Coupling Analysis
Shuvadeep is on a distinguished road
I am trying to simulate a coupled analysis between Fluent and Transient structural. The structure should rotate about z-axis and update this rotation in Fluent to calculate the fluid forces and moments. This forces should in turn be updated in structural and so on.
The structural rotation doesn't update in Fluent and the solution runs without any errors. However when I open CFD Post, the FF system of Fluent doesn't have any structural rotation and computes the flow field in the initial orientation only. But the SYS shows the structure has rotated through certain degrees. Why is this happening?
Shuvadeep is offline   Reply With Quote
dynamic mesh, fluent, fsi, system coupling, transient structural
Remeshing_ ANSYS 14.0_ System Coupling acdesa ANSYS 4 November 2, 2016 10:12
ANSYS WORKBENCH Transfer result of one analysis to a new analysis as preload ingjuanm90 ANSYS 0 July 26, 2016 15:04
Ansys CFX exited with return code 1. dheelibun CFX 8 May 7, 2014 08:21
Pump Cavitation Analysis in ANSYS CFX techCAE CFX 6 July 3, 2013 07:37
[ANSYS Meshing] steady-state thermal analysis in ansys workbench zenwalk ANSYS Meshing & Geometry 3 March 19, 2012 22:40
