UDF program for pressure calculation in a pipe |
July 24, 2019, 06:13 |
vighnesh
Hello there,
Im working on Ansys fluent. As I am new to UDF,need some suggesions. How can i write a UDF program so that in a pipe having 2 points p1 and p2, i need to calculate all the variable parameters addressed in one program i.e calculate p1-p2 with varieing inlet velocity for regular interval of time say for first 100 sec velocity is v1 next 100 sec velocity is v2 and so on for 2000sec. I have calculated manually using fluent where i give initial velocity manually everytime i.e. for velocity v1 i calculate p1,p2 @ time 0 to 100sec again change Initial velocity to v2, calculate p1 and p2 for 100 to 200 sec so on.. i need this to be done using a UDF program. Note: Solver pressure based Time--> transient Thanks, Vighnesh |
Friction Factor Calculation in Pipe | morteza08 | Main CFD Forum | 7 | May 8, 2023 15:42 |
[DesignModeler] DesignModeler Pipe within pipe | shields | ANSYS Meshing & Geometry | 13 | November 25, 2018 22:14 |
Problem with interpreted UDF with UDM calculation | Kabador | FLUENT | 4 | July 8, 2018 03:36 |
Fluent/icepak UDF for heat pipe simulation | debuger | Fluent UDF and Scheme Programming | 0 | July 19, 2017 12:05 |
Pipe system program | Carlos Daniel | Main CFD Forum | 0 | May 25, 1999 20:40 |
