WENO scheme on curvilinear coordinates
Old   July 16, 2019, 10:57
Default WENO scheme on curvilinear coordinates
Selig
selig5576 is on a distinguished road
I've been developing a curvilinear FVM code. So far I've implemented the PPM scheme and am looking into adding WENO schemes. So far I've been discretizing the grid metrics using a second-order central.
For the WENO scheme will I need to use a higher-order scheme (5th order?) for the grid metrics. When I use the WENO scheme in curvilinear coordinates I get numerical oscillations, which makes me believe it has to do with the grid metrics. I've implemented the WENO scheme on a purely cartesian grid to verify the implementation was done right.
selig5576 is offline   Reply With Quote
Old   July 17, 2019, 13:46
Default Bump
Selig
Bump. Any ideas?
Old   July 17, 2019, 17:09
Eifoehn4's Avatar
Eifoehn4 is on a distinguished road
Generally linear metrics should be sufficient for high order methods even on fully unstructured meshes. This may not hold for cases including boundary conditions, e.g. walls.
But i am no expert for WENO methods, i only can state that this holds for DG methods.
Check out my side project:
A multiphysics discontinuous Galerkin framework: Youtube, Gitlab.
Eifoehn4 is offline   Reply With Quote
Old   July 17, 2019, 17:45
Default Weno
Selig
That seems reasonable. I will try doing a high-order accurate discretization for the grid metrics.
Random question: Can one formulate a curvilinear transformation for DG methods similar to structured methods (such as FDM and FVM?) Or are your options structured (Cartesian) or unstructured (quads, triangles ,tets, etc)meshes.
Old   July 18, 2019, 03:49
Eifoehn4's Avatar
DG methods are not limited to linear meshes. Curved meshes are easy to implement.
WENO scheme validation - rhoCentralFoam - shockTube/Shu-Osher problems usv001 OpenFOAM Running, Solving & CFD 4 September 14, 2017 13:06
A way to optimize the WENO scheme by optimizing the coefficients of linear scheme moon_light Main CFD Forum 1 November 27, 2012 10:19
WENO SCHEME BASICS Help Required!!! John Main CFD Forum 1 January 18, 2007 04:16
Finite Volume WENO Scheme DSS Main CFD Forum 3 January 15, 2007 04:47
Flux splitting for WENO scheme DSS Main CFD Forum 6 January 10, 2007 11:59
