How can I find the recommended y+ values for turbulence models?
Old   July 12, 2019, 19:26
Default How can I find the recommended y+ values for turbulence models?
Bran is on a distinguished road
How can I find the recommended y+ values for turbulence models such as realizable k-epsilon and SST k-omega?
Once I find these can I use them to calculate a first cell height during meshing?
Thank you.
Update: according to some material I found from ANSYS, walls can be resolved in two ways:
1. wall functions, where the y+ value lies between 30 and 300 (30<y+<300)
2. resolving the viscous sublayer, where y+ should remain at 1 or very close to 1.
It seems like there's no recommended y+ values for different turbulence models, instead for the strategy used to mesh the walls.
Bran is offline   Reply With Quote
ansys, fluent, turbulence, y+ value
Velocity values are normal but pressure values are too big rv82 OpenFOAM Running, Solving & CFD 4 April 13, 2015 04:59
Minimum Recommended Yplus High-Re Turbulence Models minger OpenFOAM Running, Solving & CFD 2 August 16, 2013 10:29
Numerical errors in nested domain with pre-calculated boundary values Arnoldinho OpenFOAM Running, Solving & CFD 3 April 4, 2012 11:31
How to set reference values to find Cl, Cm... (3D) Cyril FLUENT 5 June 26, 2006 12:22
setting reference values to find Cd, Cl, Cm (3D) Jeff FLUENT 0 June 23, 2006 02:10
