Ho to justify that the problem is stiff in numerical study
Old   July 11, 2019, 18:08
Default Ho to justify that the problem is stiff in numerical study
Amir
ALBATTROSS is on a distinguished road
Hello all,
I'm solving a transient natural convection problem using finite-volume method and comparing it with another results with different approach. The problem is in order to recover their results I should do a lot of iterations (2000 ) in each time-step in FLUENT's fully implicit transient solver, otherwise, the transient solution comparison has a very large error (for example using 20 iterations instead of 2000 is very off) but the steady-state results have very small error. The problem is, in order to be able to iterate that much I should set equations residuals criteria as low as 10^-12. My conclusion is this problem is very stiff so the equation residuals are as low as 10^-12 but the variable residuals are 10^-3 I want to justify this idea so I need to prove why the problem is stiff, can you guys help me finding sources that justified a problem like this. or any past experience with situations like this that can ignite another idea?
Thank you
ALBATTROSS is offline   Reply With Quote
Grid independent study problem wzhang11 STAR-CCM+ 5 February 19, 2016 10:03
Numerical Scheme for a CFD problem Saturn_V Main CFD Forum 8 September 25, 2013 03:54
Numerical problem in buoyantBoussinesqPimpleFoam vtcampos OpenFOAM Pre-Processing 2 July 7, 2013 08:55
error problems between experimental and numerical study d118i Siemens 4 June 18, 2010 13:45
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 10:11
