Boundary Conditions for an impeller
Old   July 8, 2019, 21:11
Default Boundary Conditions for an impeller
rj26 is on a distinguished road
Hello Everyone
I am carrying out a simulation of a steady simulation of a centrifugal fan.
The experimental values I have are :
Total Pressure 918.07 N/m2
Static pressure 86.36 N/m2
Velocity Pressure 94.141 N/m2
Flow rate 3.426 kg/s
And Shaft power 3.62 kW
My boundary conditions are the following
Two stator bodies (inlet bellmouth and stationary outlet ) and a rotatory body (impeller)
Turbulence model: SST
Wall distance Y+ <10
Convergence criteria: 10-5
Number of nodes: 1.3 million
Rotor RPM: 1760
My simulation converges properly and velocity and pressure residuals reach below 10^-5 after 400 steps.
I tried two inlet and outlet conditions :
Operating pressure: 1 atm
Condition 1 : Intel condition: Flow rate : 3.426 kg/s and Outlet pressure : 0 atm
Condition 2 : Inlet condition : Inlet pressure : 918.07 N/m2 and outlet pressure : 0 atm
When I calculate the shaft power from the simulation results the values show more than 50 % error. Calculate shaft power for condition 1 was 1.9 kW and for condition 2 was 0.8 kW.
I am not sure why I am getting such low values. My suspect is the boundary condition.
Please let me know how to solve it.
Thank you
rj26 is offline   Reply With Quote
Old   August 2, 2019, 09:44
Eyyup DUMAN
Sigmapi is on a distinguished road
hi ,
Did you try inlet BC :0 pa
outlet BC : ...kg /s Mass flow?
Sigmapi is offline   Reply With Quote
Old   August 3, 2019, 03:04
Hamid Zoka
Hamidzoka is on a distinguished road
Hi;
- Try total pressure @ inlet and massflow @ outlet.
- Check the physics of flow through the impeller.
- Compare the calculated velocity levels with those available from experimental values.
- Recheck the torque calculation equations.
Regards
Hamidzoka is offline   Reply With Quote
cfd, fan, impeller, mrf.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
CGNS Boundary conditions using SU2 denzell SU2 3 July 9, 2018 06:58
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 22:16
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 10:49
