#41 |
james nathman
Rep Power: 15 ![]() |
This movie.
#42 |
amin95
Rep Power: 7 ![]() |
Thanks for your reply.
I could manage to solve the problem. It was a numerical error within MATLAB while calculating influence coefficients. Changing range of atan2 from [-pi,+pi] to [0,+2pi] with MATLAB's mode function had caused numerical errors. I'd like to ask some questions if you don't mind. 1) Is double wake method good for simulating post stall flows over wings? 2) How could i simply model a wing's aileron with 3d panel method ? 3) Could wake panels go through a body surface without causing problem? (for example when wing's wake in an aircraft face rear vertical and horizontal stabilizers surface) 4) Could i use Dirichlet boundary conditions for lifting parts and Neumann boundary condition for non lifting parts simultaneously in 3d panel method? Best Regards |
#43 |
Zack
Rep Power: 10 ![]() |
Actually I am writing panel method code for flow separation as well.
#44 |
amin95
Well then, maybe we could help each other. Which method you use for modelling flow separation of post stall? Double wake, Decambering or ...
boundary element method, panel method |
Linear-Strength Vortex Unsteady Panel Method (2D) | Sonik_87 | Main CFD Forum | 18 | February 23, 2020 09:16 |
The difference between Blade Element Method and Panel Method? | mrswordf1sh | Main CFD Forum | 2 | November 22, 2014 10:55 |
2D Field Panel Method Source Code | Shukla | Main CFD Forum | 3 | January 20, 2011 12:51 |
Please: Looking for a Panel method or vortice lattice for windmill | be_inspired | Main CFD Forum | 10 | April 1, 2009 16:53 |
Problem building 3D Panel Method | Daniel | Main CFD Forum | 0 | September 15, 2006 07:51 |
