3D Panel Method Code
Like Tree17Likes
Old   July 18, 2019, 18:28
amin95
amin95 is on a distinguished road
I'd like to add this, that the normal vectors of the wing panels are toward external flow and I calculate the inverse tangent functions of influence coefficients in range of (-pi/2,+pi/2). Are these assumptions correct?
amin95 is offline   Reply With Quote
Old   July 18, 2019, 18:34
james nathman
blackjack is on a distinguished road
Now that I know your panel method is time stepping, attached is the solution history of lift coefficient for your wing. In each solution, the wing moves one chord length. The lift coefficient is asymptotic to the steady-state value in 10 chord lengths.
The second figure shows the wake at step 20, colored by circulation.
Instead of calculating the wake strength, you could specify the steady-state values (from Kutta-Joukowsky). If the wing does not mirror the specified circulation, the influence coefficients are wrong. If the wing does have the correct circulation, the calculation of the wake circulation is in error.
amin95 likes this.
blackjack is offline   Reply With Quote
Old   July 20, 2019, 13:17
james nathman
The off-diagonal influence of the body panels for any shape will vary from -.5 to 0.5. For your convex geometry they will be between 0 and 0.5. Yours are.
amin95 likes this.
Old   July 20, 2019, 20:23
amin95
Thanks to your help I think I made a progress and could find a mistake i had made regarding to the sum of the trailing edge wake panels coefficients to the trailing edge upper and lower panels coefficients. After correcting I run the code at 5 degree of AoA and got these figures:
The CP distribution figure looks correct except at the trailing edge panels where the results are still divergent. I omitted the trailing edge panels contribution to total lift and I got this figure of CL vs timesteps which looks similar to your posted figure.
I also posted doublet strength of the wing panels. there is a big gap between upper and lower trailing edge panels values.Could you please upload the correct doublet strength of wing and wake panels?
Thanks,
Old   July 20, 2019, 22:54
james nathman
Airfoil potential (doublet) distribution looks good.
How are you calculating t.e. panel pressures? Backwards difference of t.e. panel and panel upstream? There must be an error here because the potential distribution you have does not have large gradient (velocity).
amin95 likes this.
Old   July 21, 2019, 01:06
james nathman
I should have been more precise: how is gradient of potential calculated for t.e. panel to get velocity?
amin95 likes this.
Old   July 21, 2019, 08:32
amin95
I use the same central difference method for calculation of perturbation velocities at t.e. panels:
ql = ( 1/(2*L) ) * ( Mu(i+1) - Mu(i-1) )
L : panel (i) length in l direction
Mu : doublet strength of panel (i)
ql : perturbation velocity of panel (i) in l direction
But after considering the discontinuity between doublet strengths of t.e. panels I used following method for t.e. panels to avoid that issue :
ql = (1/L) * ( M(i) - Mu(i-1) )
And now it seems by using this method for t.e my code could calculate the results correctly. is this difference method okay for t.e. panels?
I uploaded my new results. Could I assume now that my 3d panel code is correct and would work for any other arbitrary 3d shapes too (like modelling an aircraft in low speed)?
Best regards,
Old   July 21, 2019, 16:06
james nathman
Excellent. You have wisely chosen a case with 90 panels (5 spanwise, 18 chordwise).
Try increasing the panel density and look at drag, look at execution time.
An arbitrary aircraft (e.g. twin-engine transport with flaps, fuselage, engines, pylons, vertical tail, horizontal tail) is typically modeled with 9000 panels.
Add a fuselage to your wing. Add horizontal and vertical tails. Add pylons and engines.
Can your code model inlets/exhausts? Wing/body intersections? Wake/body intersection?
For "arbitrary" you have much work ahead of you.
The quickest way to find the limitations of your code is to let someone else use it.
Good Luck.
amin95 likes this.
Old   July 21, 2019, 20:49
amin95
Dear Mr. Nathman,
I truly appreciate your assistance. You helped me to solve my problem and I'm deeply grateful. Please also accept my apology for taking your precious time.
I'm a master's student and my thesis is about modelling of a Tiltrotor aircraft. I have my profile at "www.Researchgate.net".
Regarding to your questions, I'm aware that difficulties exist in modelling of an aircraft with 3d panel method and I think there are different approaches for these issues but for now all I know is that I could divide a whole aircraft surfaces into lifting(rotors, wings,VS,HS) and non-lifting (fuselage,nacelles,hubs) without losing much accuracy.
Finally, I'd be glad if I could use your advice and works regarding to my project.
Best Regards
Old   July 24, 2019, 17:24
james nathman
If you need my permission to quote anything I have said here, you have it.
I would like to you to note that an advantage of a potential-based panel method is that the user does not divide things into "lifting" and "non-lifting". The surfaces are all treated alike. If a wake is attached to a fuselage, it will lift.
A piece of aluminum does not behave differently depending upon whether it is the skin of a wing or of a fuselage. Likewise, the numerics of a fuselage panel are the same as a wing panel. The simplicity and generality of Morino's approach is underappreciated.
Cheers,
amin95 likes this.
Old   September 8, 2019, 14:17
Zack
ZakBristol is on a distinguished road
Hi. I think you should use atan2, rather than atan. I wonder how did you Calcute induced velocity for the wake roll up. I followed Katz formula but didn't get the right shape
ZakBristol is offline   Reply With Quote
Old   September 8, 2019, 14:24
Zack
Hi Amin. Would you be able to share the code if it is not a lot to ask.
Thanks
Old   September 8, 2019, 15:40
amin95
Thanks
Hi Zack
Yes at first i used atan then I used atan2 in range of (0,2pi) and it worked.
In wake roll up section, I used only Katz's formula for source panles induced velocties. For doublet panels I used Bio-Savart law since a constant strength doublet panel is equal to vortx ring (fig1). It is more simple than Katz's formula because you dont need to convert coordinates from global to local and vice versa again.
But you should know that Bio-Savart formula has singularity which makes induced velocity near vortex ring go infinite. So you should modify the formula with a viscous core model to get reasonable result. there are some paper addressing this issue I used this one " Enhancement of Free Vortex Filament Method for Aerodynamic Loads on Rotor Blades".
My wake roll up code has a minor problem and now I'm working on it. It works well for 15 time steps but beyond that the wake tends to destabilize.(fig2 and fig3).
I have no problem of sharing my code, In fact I would be glad if I could help you. Are you a university student like me too?
Old   September 8, 2019, 15:42
Zack
Yes I am at uni. I tried to use vortex wrings for induced velocity. But was not successful. Perhaps I have problem with my indices. Did you equal mu to gamma.?
If you can send me the code at darwichab@gmail.com I will appreciate it a lot.
Thanks
Old   September 8, 2019, 16:19
amin95
I sent the code with some description to your email address
Old   September 8, 2019, 17:20
Zack
Thanks mate
Old   September 16, 2019, 21:51
amin95
Cheers,
Dear Mr. Nathman,
I have a question about wake roll up. Why my wake panel after some time step tends to destabilize?(figure 1&2)
s this about wrong asymmetric calculation of Local vectors and influence coefficients?
Is rolling of tip wake panels related to stability of wake panels?
Old   September 16, 2019, 22:06
Zack
Dear Mr. Nathman,
I think you have a bug in calculating induced velocity. Try an even number if panels in the span direction and you can visualize the system note. That induced velocity in the y axis would have an opposite sign of the opposite side.
Old   September 17, 2019, 17:42
amin95
Hi, i had some bug and I fixed them. But the problem still exists this time in a symmetric form.(fig1)
I guess it has some thing to do with MATLAB's own calculation. for example for first time step without any shed wake still t.e wake panel has asymmetric doublet strengths.(10E-16 error). even with rounding the values, the problem appears again after some time steps. I'm still working to find cause of the problem.
Could you simulate Wake roll up successfully?
Old   September 23, 2019, 18:27
james nathman
This doesn't look like instability. The figures indicate a numerical error. Top guesses:
1. Circulation of wake panel is overwritten because of out-of-bounds subscript.
Try (1) displaying circulation of wake panels (as in zipped mpeg movie with wake panels colored by circulation).
(2) Changing time-step size: does problem occur after same number of panels generated?
(3) Changing number of wake columns but same step size.
2. If circulation is bad when panel generated, then influence coefficient is bad, either convection velocity or AIC element.
amin95 likes this.
boundary element method, panel method
Linear-Strength Vortex Unsteady Panel Method (2D) Sonik_87 Main CFD Forum 18 February 23, 2020 10:16
The difference between Blade Element Method and Panel Method? mrswordf1sh Main CFD Forum 2 November 22, 2014 11:55
2D Field Panel Method Source Code Shukla Main CFD Forum 3 January 20, 2011 13:51
Please: Looking for a Panel method or vortice lattice for windmill be_inspired Main CFD Forum 10 April 1, 2009 17:53
Problem building 3D Panel Method Daniel Main CFD Forum 0 September 15, 2006 08:51
