Calculation of Knudsen number
Old   June 28, 2019, 01:16
Default Calculation of Knudsen number
esha is on a distinguished road
Hi, I want to calculate Knudsen number and I know the formula is kn=mean free path/characteristic length. I want to calculate it for flow over a circular cylinder having slip boundary and Kn is defined by the ratio of slip length to the diameter of the cylinder. I set the slip boundary condition by using fluent. Now I do not know how to calculate the slip length as I am new to CFD. or should I use Knudsen number but how may I give it in fluent? I am confused, can someone kindly explain it. I will highly appreciate.
esha is offline   Reply With Quote
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 19:32
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 23:29
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
Stable boundaries marcoymarc CFX 33 March 13, 2013 07:39
