June 25, 2019, 04:11 |
Galvanizing process - Steady state solution
Andrea
Rep Power: 7 |
I do simulations of a hot-dip galvanizing process ( a steel strip is immersed in a molten Zn alloy bath and is guided through the bath by stabilization rolls; Aluminum is added to the bath to obtain a good adherence of the liquid Zn to the steel surface). The bath temperature is done by inductive heating with a PID Control scheme and Zn alloy Ingots containing Al compensate the zinc and aluminum consumption. The model takes into account the flow (N-S eq), turbulence (due to steel strip movement), energy and species Transport (fe and al Diffusion, Fe2Al5Znx and FeZn7 Formation) . Previous calculations proved that the K-Omega-SST model gave best results for the Zn bath Simulation , so we use K-Omega-SSt model with low Re corrections, Curvature corrections and Production limiters. Since the transient calculation is too long (1-2 weeks) we are trying to obtain a Steady state solution. We have used a SIMPLEC scheme ( in the pressure-velocity coupling solver) with reduced under-relaxation factors and the results were promising regarding convergence. So we didn't have divergence problems, and the average temperature values of temp and al conc were stable. But there were still changes in the Velocity field (contour plots) -after many hundred thousend iterations-, so the Steady state was not reached. This problem persists when we consider only flow and turbulence (without Energy and species Transport). In this case we have also tried the Coupled scheme ( in the press-vel coupling solver), but the results were even worse (fluctuations and Velocity field stability ) than in the SIMPLEC scheme. Does anyone has experience or any ideas with Steady state stability and different computational schemes in Fluent? Any answer would be appreciated. Thank you for your help. |
Steady State solution and Transient solution | ari003 | FLUENT | 1 | March 9, 2019 12:14 |
Steady state solution ----> transient | nskelly | OpenFOAM Running, Solving & CFD | 4 | March 12, 2018 11:49 |
Problem with pimpleDyMFoam: Initialise steady state solution | Lancester | OpenFOAM Running, Solving & CFD | 2 | September 29, 2015 09:49 |
Steady State solution | ajinkya1 | SU2 | 2 | November 26, 2014 04:22 |
is it possible to predict how long it takes to reach steady state solution in unstead | Alimohamadi_nasr | CFX | 4 | November 11, 2013 06:11 |
