June 23, 2019, 15:09 |
CyclicAMI BC
Jayant Ranwka
Getting this error on using cyclicAMI BC:
gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type cyclicAMI) on patch AMI2 of field U in file "/home/hp/Downloads/pp/m1/0/U" You are probably trying to solve for a field with a generic boundary condition. From function genericFvPatchField<Type>::gradientInternalCoeffs( ) const in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 832. |
June 25, 2019, 10:35 |
Kmeti Rao
Rep Power: 8 |
Hi Jayant,
The following link has a similar problem as mentioned by you, hope it helps. Looking at your error message it would be due to the wrong specification of Velocity BC gradientInternalCoeffs cannot be called for a calculatedFvPatchField Without describing the problem completely it is very difficult to provide the solution. To know more about this please visit How to give enough info to get help Regards |
Using createPatch and cyclicAMI in FOAM Extend to create periodicbox | manuc | OpenFOAM Running, Solving & CFD | 1 | April 12, 2022 12:36 |
Getting started with CyclicAMI | Algebraist | OpenFOAM | 4 | February 11, 2019 02:39 |
cyclicAMI - kOmegaSST - divergence issue | cyln | OpenFOAM Running, Solving & CFD | 1 | October 5, 2018 11:06 |
cyclic / cyclicAMI boundary conditon - ICEM Mesh | cyln | OpenFOAM Running, Solving & CFD | 0 | November 7, 2017 16:26 |
Boundary Layer strange result | fernexda | OpenFOAM Running, Solving & CFD | 14 | January 15, 2015 08:21 |
