Can someone help to check this code on Roe solver
Old   June 14, 2019, 22:20
Default Can someone help to check this code on Roe solver
cfdnewb123 is on a distinguished road
The code is found here,
https://ir.cwi.nl/pub/10964/10964D.pdf
I am trying to write my own code for Roe solver on Matlab and I have been using this paper as a guide. However when I run the code from this paper on Fortran 95, it ran into some floating point error. As I am not familiar with Fortran, I am wondering whether can someone help me check the validity of the code over here.
I am working on the Sod shock tube in particular.
cfdnewb123 is offline   Reply With Quote
Old   June 15, 2019, 04:34
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
First, depending on the compiler, use all the options to debug the code. Disable all optimizations and use the checkbound for arrays and other setting for the floating points errors in the link procedure
FMDenaro is offline   Reply With Quote
Old   June 15, 2019, 05:20
I am sorry I don't really get this as I am still new to Fortran. I am using FTN95 (https://www.silverfrost.com/). I have try to debug the code but as I am using this paper as I guide, it is really hard for me to know whether the code is correct or not.
Old   June 15, 2019, 05:23
If you compile correctly the source code, there is no conflict in the FTN95 language. You need to check the error in the run-time procedure.
Use the specific debug options in compiling the source, see here https://www.silverfrost.com/ftn95-he...lassified.aspx
fortran, riemann solvers, roe solver, shock, shock-tube
The ANSYS CFX solver exited with return code 1 kola77 CFX 24 April 11, 2022 08:32
Compilation error for OpenFoam FSI solver with third party FEA code danny261083 OpenFOAM Running, Solving & CFD 1 October 6, 2017 10:50
Changing Temperature of patch within code of solver SalvusApfel OpenFOAM Pre-Processing 1 February 24, 2017 08:29
modify the source code of simpleSRFFoam solver Pirlo OpenFOAM Programming & Development 0 October 19, 2009 09:49
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 11:46
