June 14, 2019, 12:10 |
Gravity Decanter
Mobin
Hi guys ,
I`m going to model a gravity decanter like the picture below. This decanter is used for the continuous separation of two immiscible liquids of differing densities. The feed mixture enters at one end of the separator. Two liquids flow slowly through the vessel, separate into two layers and discharge through overflow line at the other end of the separator. Provided the overflow lines are so large that frictional resistance to the flow of the liquid is negligible and provided they discharge at the same pressure as that in the gas space above the liquid in the vessel, the performance of the decanter can be analyzed by the principles of the fluid statics. Can I model this unit simply like the 2d image below? If yes, how should I set the boundary condition for such a problem? Guys have you done anything like this? I really need your help…Thanks…. Screenshot_1.jpg Screenshot_2.jpg |
June 17, 2019, 05:46 |
Rep Power: 14 |
If you want to demonstrate the principle than your sketch and a 2D approach might be sufficient.
June 17, 2019, 12:45 |
#3 | |
Filippo Maria Denaro
Rep Power: 73 |
And what should be the 2D plane you would simulate? I don't see a particular 2D section representative of the problem... |
decanter, gravity driven |
simpleFoam with gravity, based on interFoam | JonW | OpenFOAM | 1 | May 9, 2019 11:08 |
Convergence problem when use gravity | aroma | STAR-CCM+ | 1 | April 10, 2013 11:18 |
Question on Gravity | archdevil | Main CFD Forum | 9 | May 16, 2012 14:31 |
UDF fails to model 9.81m/s^2 gravity | jpo | Fluent UDF and Scheme Programming | 2 | January 24, 2012 19:15 |
how to consider gravity in CFX | shrimp | CFX | 4 | September 8, 2008 21:41 |
