June 12, 2019, 11:53 |
Simulation of Explosion
A. Min
Rep Power: 12 |
Hi all,
I want to validate my numerical procedure with the results of this paper: Computer simulation of shock waves transmission in obstructed terrains But they didn't present the explosive mass! and it cannot be calculated using presented parameters. Do you know how to find it? They also have the other paper: Experimentally validated 3-D simulation of shock waves generated by dense explosives in confined complex geometries in this paper the relation that they used for source term of energy equation to simulate the explosion, is: Code:
S = Er × step [(t − t0)(t − tf)] tF (explosion duration) = Rp/U, Vp (explosion sphere volume) = Mp/dp, Er (explosion energy released) = Q_DET * Mp/tF where Rp is the radius of explosion sphere, U is the explosion velocity, Mp is the explosive mass, dp is the explosive density, Q_DET is the Mass specific energy. With these relation every parameter can be calculated correctly, but not for the first paper! However, I found the other paper: Simulating geometrically complex blast scenarios they mentioned that they used last paper relation, but they used: Er = Q_DET/Vol*(dV/dt) and dV/dt = 4*pi*Vcj^2*t^2 for t<tF and r < rDet that is different from this paper. Could you please tell me which one is correct? I'm really appreciated if sb answers me. |
Some questions about flow boiling simulation in Fluent | beastieboys6 | FLUENT | 8 | November 21, 2017 00:47 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 03:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 16:06 |
Looking for information for simulation of explosion in deep water or enclosed space | richard | FLUENT | 6 | January 6, 2016 03:06 |
SP3D converter or explosion simulation software | Wing | Main CFD Forum | 0 | December 10, 2008 14:24 |
