May 31, 2019, 16:30 |
Custom Field
federico
Rep Power: 7 |
Hi there,
I'm using the boxtocell function to insert a certain volume fraction value into a bottle. In the "constant" I can define as the parameter, in addition to the viscosity and density, the diameter of the bubbles. Please note, i'm using a mixturemodel (https://www.vtt.fi/inf/pdf/publications/1996/P288.pdf). Not having yet implemented the population balance and therefore the growth of the bubbles, I wanted to know if it was possible to set different bubble diameter values within the "boxtocell" field, increasing it along the z coordinate (even discreetly) to make time tests of ascent. |
boxtocell, constant, multiphase, setfields |
problems after decomposing for running | alessio.nz | OpenFOAM | 7 | March 5, 2021 04:49 |
[Other] dynamicTopoFVMesh and pointDisplacement | RandomUser | OpenFOAM Meshing & Mesh Conversion | 6 | April 26, 2018 07:30 |
How to calculate pressure forces using custom field functions? | tsagaro | FLUENT | 7 | June 23, 2017 15:45 |
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL | AndoniBM | OpenFOAM Running, Solving & CFD | 2 | March 25, 2015 18:44 |
custom field function | greg | FLUENT | 2 | May 23, 2006 10:42 |
