Initial Velocity in Spray Modeling
Old   May 10, 2019, 11:48
Default Initial Velocity in Spray Modeling
Shaikh
safiullahs1 is on a distinguished road
I'm comparing diesel spray characteristics in AVL FIRE with experimental results but penetration length of my simulation is much shorter. But when I introduce initial velocity (labelled as Droplet "start velocity" in Nozzle section of SSF), penetration length of my CFD calculation becomes almost identical to experimental results. Is it a good idea to use start velocity? By the way, I input experimental measured injection rate (Zuech Method) in my calcuation.
Thanks.
safiullahs1 is offline   Reply With Quote
Old   May 13, 2019, 04:04
Steve
steve lee is on a distinguished road
Usually, In spray simulation..
You should find break up model constants first..
and you have to consider delay time (it is very important)
steve lee is offline   Reply With Quote
avl fire 2013, diesel spray, droplet velocity, initial velocity, injection rate
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 15:26
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
