Vortex shed frequency of an velocity array in MATLAB |
May 5, 2019, 05:39 |
Rep Power: 7 |
There was conducted ten different experiments, with ten different velocities in an air chamber where air at 25 degrees Celsius was blown at a cylinder of 20mm. The measurements were taken by a hot-wire anemometer a certain distance behind the cylinder. The frequency of measurements were 1000Hz and we were given ten different files with one array in them with velocities.
The end goal is too make two graphs, one showing vortex shed freq vs Velocity, and Strouhal- vs Reynolds number as a function of Re, and finding uncertainties considering dU=0,1. I do know the formulas for the two last variables: Code:
St = f*D/U Re = rho*U*D/mu I am not sure if I am supposed to do anything with the start like windowing or what not. What I have done here is to use FFT and nyquist limits and making PSD out of it. I have the impression that if i take the max value of each of these plots and plot them against the velocity I will have what i requested first. However with the start value being so high for each of them the plot is a straight line. I am not looking for anyone to do it for me, but rather if anyone could point me to relevant information about my problem. If it was not clear i am doing this in MATLAB. |
May 5, 2019, 06:06 |
Filippo Maria Denaro
Rep Power: 73 |
First of all, the zero-th wavenumber in the spectra is the average energy content, try to plot the spectra in a log-log scale without the zero.
Then, consider that your time-signal is not exactly periodic, are you performing the FFt over the whole interval or are you using windowing technique? |
May 5, 2019, 07:50 |
#3 | |
Rep Power: 7 |
Thanks for the reply! I am not currently using a windowing technique, as I am unsure if its appropriate in this case. When I should remove the zero-th wave number is this before or after the FFT? If it is the later i get this for my plots: Do these to plots look like something that could be correct? |
May 5, 2019, 08:03 |
Rep Power: 73 |
Remove only from the plot, first of all show the energy spectra resulting from the whole signal in a log-log plot
May 5, 2019, 08:17 |
#5 | |
Rep Power: 7 |
Okey so I plotted this: Code:
loglog(PSDx{i}) Code:
%% Number of points N = numel(Ucell{i}); % Lenght of signal %% FFT xdft{i} = real(fft(Ucell{i})); xdft{i} = xdft{i}(1:N/2+1); % Nyquist %% PSD - Power Spectral Density PSDx{i} = (1/(fs*N)) * abs(xdft{i}).^2; PSDx{i}(2:end-1) = 2*PSDx{i}(2:end-1); Last edited by nikla; May 5, 2019 at 08:23. Reason: fixed img |
May 5, 2019, 08:44 |
Rep Power: 73 |
what are you exactly representing in x and y axes? If 10^3 Hz is the Nyquist cut-off how can you plot higher frequencies??? What is exactly the time-step of your measurement device?
May 5, 2019, 09:17 |
#7 | |
Rep Power: 7 |
Sorry I tought wrong, and plotted wrong. It now cuts of at the nyquist limit 500hz. Code:
%% Load test data Ucell = {load('3d7.lvm') load('5d5.lvm') load('7d1.lvm')... load('8d7.lvm') load('11d9.lvm') load('14d4.lvm') load('16d5.lvm')... load('18d9.lvm') load('20d8_1.lvm') load('20d8_2.lvm')}; UL = numel(Ucell); U = [3.7 5.5 7.1 8.7 11.9 14.4 16.5 18.9 20.8 20.8]; % m/s %% Variables and Conditions D = 0.02; % [m] Diameter of cylinder T = 25; % [C] Tempratur rho = 1.184; % [kg/m^3] Air density mu = 18.37e-6; % [N*s/m^2] Dynamic (absolute) viscosity deltaU = 0.1; % [m/s] speed change fs = 1000; % [Hz] Sampling frequency ts = 1/fs; % [s] Sample time Ns = fs/2; % [Hz] Nyquist sampling frequency %% Calculating % Preallocation for i=1:UL %% Number of points N = numel(Ucell{i}); % Lenght of signal % t{i} = (0:N-1)*ts; % Time vector %% FFT xdft{i} = real(fft(Ucell{i})); xdft{i} = xdft{i}(1:N/2+1); % Nyquist %% PSD - Power Spectral Density PSDx{i} = (1/(fs*N)) * abs(xdft{i}).^2; PSDx{i}(2:end-1) = 2*PSDx{i}(2:end-1); freq{i} = 0:fs/N:Ns; %% Max value [M(i),I(i)] = max((PSDx{i})); I(i) = (I(i)*Ns)/N; % Getting the frequency and not indic place %% Strouhal number and Reynolds number St(i) = (M(i)*D)/U(i); % Strouhal number Re(i) = (rho*U(i)*D)/mu; % Reynolds number end %% PSD figure(4) for i=1:UL subplot(numRow,plotsPerRow,i) loglog(freq{i},PSDx{i}) title(sprintf('U=%0.5g [m/s]', U(i))) xlabel('Frequency (Hz)') ylabel('PSD') grid on end sgtitle('Loglog') linkaxes % Same axis range for all |
May 5, 2019, 09:37 |
Rep Power: 73 |
But you must not cut the plot, your whole signal contains frequencies only up to the Nyquist one and that means you perform the FFT on the whole signal and then plot the squared modulus of all Fourier couefficients along each frequency.
And the Nyquist frequency is pi/dt, what is yout dt? |
vortex shedding frequency |
Induced downwash velocity for drag computation in Vortex Lattice Method (VLM) | Sehwan | Main CFD Forum | 3 | September 13, 2018 15:33 |
Vortex shedding frequency from cylinder | UOWmecheng | CFX | 7 | July 14, 2016 20:05 |
time step and vortex shedding frequency | kevin | Main CFD Forum | 16 | November 19, 2009 07:00 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
Free vortex - forced vortex | Armin Hofstädter | Main CFD Forum | 2 | November 17, 1998 19:55 |
