Temperature Contours / Isotherms
Old   April 22, 2019, 14:19
Default Temperature Contours / Isotherms
Ujjwal Mohanty
ujjwalmohanty is on a distinguished road
I am trying to simulate flow over heated triangular pipe in 2D in FLUENT.
My boundary conditions:
Top and bottom wall : Symmetry
Inlet : Temp : 300K, air velocity : ranging from 50 to 250 m/s based on Re.(I have taken viscosity and density of fluid as 1 for simplicity)
Cylinder (triangular pipe) : Temp:400K, no slip condition
Outlet : Pressure Outlet
Please check the attachment to see the temperature profile I am getting for transient run.
1. How do I get isotherms in the form of vortex shedding patterns?
ujjwalmohanty is offline   Reply With Quote
Old   April 22, 2019, 15:34
Lucky
What is the question exactly?
You have a plot of temperature contour, which is a plot of a bunch of isotherms.
And what do isotherms have to do with vortex shedding?
LuckyTran is online now   Reply With Quote
Old   April 23, 2019, 16:31
Ujjwal Mohanty
Hi Lucky,
I am sorry if I was not clear with my question.
I plotted Temperature (static temperature) contours and got the image that I attached in my original question.
However I was expecting of the sort that I have attached with this comment.
I plotted the same contours in both the cases.
Why am I getting different contours?
Old   April 23, 2019, 18:59
Lucky
Which picture is which? And where do you get them from?
The original picture looks like there is no flow (or too much viscosity). Probably because you set the viscosity to 1.
You can also compare the velocity fields, probably they'll look very different.
Just check your settings and make sure you use the right settings to get the right results.
cfd, isotherms
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
UDF to get the average temperature of a face and use it to define a property gdb Fluent UDF and Scheme Programming 19 November 3, 2022 04:11
Shadow Wall and temperature norger FLUENT 10 September 28, 2019 12:43
Inlet won't apply UDF and has temperature at 0K! tccruise Fluent UDF and Scheme Programming 2 September 14, 2012 07:08
Too low temperature at combustor outlet romekr FLUENT 2 February 6, 2012 11:02
