The division of Reynolds number for flow around airfoil
Old   April 10, 2019, 03:07
Default The division of Reynolds number for flow around airfoil
Jiadong Wang
jiadongw is on a distinguished road
I’m working on the flow around the oscillating foils, in which the fluid is water. I found lots of posts include the terms “low Reynolds number” “high Reynolds number”. But none of them give the absolute range for these terms.
That’s what I’m confused.
So for the problem of flow around a NACA foil, which range of Reynolds number can be called low Re? Which range Reynolds number can be called high Re? And which range can be called medium Reynolds number?
Thank you.
jiadongw is offline   Reply With Quote
Old   April 10, 2019, 10:12
Lucky
Low and high are subjective and relative. If they don't mention any specific number referring to a specific flow situation then there is no meaning to it. This is not a Starbucks or fast food restaurant where you have small, medium, and large sized servings.
Old   April 10, 2019, 20:32
Jiadong Wang
Thank you for your reply.
You are definitely right. I found such idea in other posts.
airfoil, reynolds number
2D simulation of a Transonic Airfoil at high Reynolds number ClAuDi0 STAR-CCM+ 1 November 18, 2018 15:25
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 13:55
Reynolds number in 2D airfoil simulation jck OpenFOAM Running, Solving & CFD 2 June 3, 2016 04:56
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 15:49
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
