April 3, 2019, 05:48 |
swirl flow in t-junction pipe
Andrea
Rep Power: 8 |
Hello, i'm stuck with a problem.
I'm running a simulation of a ch4 gas in a pipeline with a t-junction. Downstream of the junction, turbulence viscosity ratio is exeding 1e5 in a lot of cells. I tryed with a lower value of velocity and the simulation did converge but with higher value did not. After this test i thought the problem was strong gradient downstream of t-junction so i refined the grid in that area, though the residuals did not reach 1e-6, they are stuck to 1e-4. I even run a test with different numerical schemes. With first order upwind for all the variables the simulation converged, but with second oreder did not. Having a group of cells with turbulence viscosity ratio up to 1e5 means that production of turbulence kinetic energy is way too large. What am i missing? Am i doing something wrong? How can i improve my simulation? thanks for your help |
High values of heat transfer coefficient for laminar flow in pipe | Allankey | CFX | 2 | May 28, 2014 13:44 |
Two-phase flow in a circular horizontal pipe | DmitryS | Fluent Multiphase | 0 | May 17, 2014 17:22 |
Reverse Flow at Rotating Pipe Outlet | vismech | STAR-CCM+ | 1 | August 11, 2009 11:38 |
About Turbulence Intensity (Pipe flow assimilated) | gRomK13 | Main CFD Forum | 1 | July 10, 2009 04:11 |
Turbulence in a pipe flow | JM | Main CFD Forum | 4 | December 21, 2006 05:04 |
