Does solenoidal field orthogonal to dilatational field? |
April 11, 2019, 04:46 |
#21 | |
Filippo Maria Denaro
Rep Power: 73 |
If you start from the Fourier series expressing u(x) as sum of U(k)*exp(i*k*x) you see the definition by using a single component du/dx = U(k) d/dx exp(i*k*x) = i*k*U(k)*exp(i*k*x)= i*k*u(x) you can think about the derivative of the spectral interpolant, see https://people.maths.ox.ac.uk/trefethen/7all.pdf A clear explanation of the two approaches is provided in section 2.1.3 of the textbook https://www.springer.com/us/book/9783540307259 see also here, note 4 raised the point about the complex derivative https://math.mit.edu/~stevenj/fft-deriv.pdf However, you are working on the divergence-free function so I would use the equation like kx*U(kx)+ky*V(ky)+kz*W(kz)=0 Last edited by FMDenaro; April 11, 2019 at 12:38. |
April 11, 2019, 17:44 |
#22 | |
But come back to my previous question: after I decompose the velocity field in spectral space and inverse FFT the velocity fields back to physical space, the imaginary parts are not close to zero. I tested my HHD code on Taylor-Green vortex, it works perfectly well; so I don't think it's the issue with my HHD code. Now I am thinking could it due to aliasing? Otherwise, I don't see other possibilities. |
April 11, 2019, 18:04 |
#23 |
Rep Power: 73 |
when you consider the derivative, you get [i*k*U(k)]*exp(i*k*x), the term in the square brackets is the Fourier transform of du/dx, have a look at Eq.(2.6) in the Trefethen notes.
April 12, 2019, 03:21 |
#24 | |
Rep Power: 14 |
being trigonometric expansion with being your modal basis functions and are your modal coefficients (spectral). You can also define the same polynomial in Lagrange form with being the Lagrange expansion with being your nodal basis functions and are your nodal coefficients (physical) Here is the same polynomial in different representation. You call the discrete Fourier-transform and its inverse. Formally you can write both or because a polynomial is a polynomial is a polynomial, or to put it another way, it is only a case of representation. Perhaps it is better to write or vice versa with being the the vector of modal coefficients and being the the vector of nodal coefficients The discrete Fourier-transform only changes the coefficients. |
April 12, 2019, 10:17 |
#25 |
This is how I would get the spectral derivative dy/dx of a periodic function y(x) in MATLAB for a given set of coordinates x with constant spacing:
%MATLAB SECTION nx=length(x); Lx=x(end)-x(1); y=y(1:end-1); nx=nx-1; %Remove periodicity Nc=(nx+mod(nx,2))/2-1; kx1=2*pi*(0:Nc)/Lx; kx2=2*pi*(-Nc:-1)/Lx; if mod(nx,2)==1 kx=[kx1 kx2];else kx=[kx1 0 kx2];end y_hat = fft(y); dydx_hat = 1i*kx.*y_hat; dydx = real(ifft(dydx_hat)); dydx = [dydx dydx(1)]; %Add back periodicity %END OF MATLAB SECTION where the remove and add-back periodicity are NOT needed if the end points are NOT actually the same. For example, use it for finite difference computations but not finite volume ones. |
April 12, 2019, 19:52 |
#26 |
April 12, 2019, 19:54 |
#27 | |
By my question was: the solution I got back from iFFT is complex, and the imaginary part is significant. I believe it's due to the aliasing errors. So I am wondering is there anyway I can separate these aliasing errors, analyze them quantitatively? |
April 13, 2019, 04:14 |
#28 |
Rep Power: 14 |
April 13, 2019, 07:42 |
#29 | |
In general, I would use a test field to see that everything works as expected, before moving to the actual data you have no control over. |
April 13, 2019, 09:39 |
#30 | |
Rep Power: 73 |
Have you checked your FFT and iFFT processes first on a known derivative? What happens if you consider a function like sin(2*pi*k/L) for several values of k? |
April 13, 2019, 09:41 |
#31 |
Rep Power: 73 |
Have also a look to the HHD in spectral space here
http://bohr.physics.berkeley.edu/cla...amclassemf.pdf |
April 13, 2019, 19:19 |
#32 | |
And I checked the note you attached. It is the same as what I did. So, I believe the complex issue stems from the aliasing error. |
April 13, 2019, 19:21 |
#33 | |
April 13, 2019, 19:23 |
#34 | |
Peterson, Livescu, Forcing for statistically stationary compressible isotropic turbulence. PoF (2010). And I made a mistake; it actually should be where And yeah, the topic kinda drifted away.... |
April 13, 2019, 19:33 |
#35 | |
However, Taylor solution, if I recall well, is soleinodal. You should try something that is dilatational as well, if you haven't already. |
April 13, 2019, 19:34 |
#36 | |
As for the aliased field, do you happen to know any? |
April 13, 2019, 19:42 |
#37 |
In 2d the taylor solution can be parameterized with respect to the wavelength. You can check my phd thesis here on my blog for it (but it is easy to derive as well). Just use a wavelength higher than what your resolution can sustain
April 14, 2019, 04:53 |
#38 | |
Rep Power: 73 |
To assess if the problem is in the aliasing you should replicate a controlled test. On a grid of size h and Nyquist frequency Kc=pi/h, sample the function sin (k*x) for k<Kc and k>Kc and check the resulting FFT/iFFT for the function and derivative |
April 14, 2019, 22:40 |
#39 | |
clearvars; clc; close all N = 64; L = 2*pi; dx = L / N; x = 0 : dx : L; w = 33; y = sin(w * x); % FFT/iFFT yk = fft(y(1:end-1)); yp = ifft(yk); % derivative k = [0:N/2-1, -N/2:-1]; dydxhat = 1i * k .* yk; dydx = ifft(dydxhat); |
April 15, 2019, 04:34 |
#40 |
Rep Power: 73 |
"But the resulting y is practically zero"
what do you mean? I run your code at w=1,16,33 and checked the y and yp vectors and they are not zero |
compressible flow, dilatational, helmholtz decomposition, solenoidal |
simpleDyMFoam on v1806 | gamemakerh | OpenFOAM Programming & Development | 0 | November 8, 2018 09:15 |
potential flows, helmholtz decomposition and other stuffs | pigna | Main CFD Forum | 1 | October 26, 2017 09:34 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Zero size field | taranov | OpenFOAM Bugs | 2 | April 20, 2010 05:51 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
