March 27, 2019, 06:29 |
Pressure Drop
cerez
Rep Power: 7 |
Hi everyone i have a question with hose pressure drop analysis.
I am doing try to find rubber hose pressure drop on intake system. Material:Air flow:turbulance Pressure based inlet boundary condition mass flow:0.1kg/s Temperature of fluid:200C pressure 165kPa I dont know what should i write on outlet boundary condition. Please if u know the answer help me. Sorry for bad english |
March 27, 2019, 11:54 |
#2 | |
Lane Carasik
Rep Power: 15 |
March 27, 2019, 12:06 |
Lucky
Rep Power: 66 |
Two ways.
1) Mass-flow inlet and a pressure outlet, with the outlet pressure of 165 kPa. This is the most robust way. 2) Other way is to do a pressure inlet with inlet pressure of 165 kPa. Use a presssure outlet with the targeted massflow rate outlet. This is slightly less numerically robust but should also work. It's just a question of whether you want to fix the inlet pressure or outlet pressure to 165 kPa. Also keep in mind that at inlets you're specifying the total/stagnation pressure (not the static pressure). |
March 28, 2019, 04:13 |
cerez
Rep Power: 7 |
March 28, 2019, 04:24 |
#5 | |
cerez
Rep Power: 7 |
i try almost every outlet boundary condition with the program that i use with. i use scflow14. i will add a picture on the below that i can not fine pressure distribution on the hose. inlet.PNG Pressure.png Outlet boundary condition.PNG by the way i am using air(incompressible) as a fluid. Last edited by cerez; March 29, 2019 at 07:23. |
March 29, 2019, 08:53 |
Found the solution
cerez
Rep Power: 7 |
I found the solution i should have write outflow B.C to -0.1kg/s mass flow and inlet to 165kPa.
After i analysis i found the almost close result. like 2kpa pressure drop |
pressure based, pressure drop |
Fluent cyclone pressure drop | mkal | FLUENT | 1 | February 20, 2020 01:55 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 06:35 |
Pressure drop using Fan type BC | Alexis Sack | OpenFOAM Running, Solving & CFD | 2 | September 22, 2014 10:18 |
How to study pressure drop of continous phase in VOF model | sajeesh | FLUENT | 4 | February 5, 2014 23:01 |
Pipe Flow - Pressure Drop | Daniel L | FLOW-3D | 2 | December 10, 2010 05:23 |
