Geometry setup for phase change problem
Old   September 28, 1998, 18:07
Default Geometry setup for phase change problem
Fred G. Kang
Hello CFD experts,
I have done the simulation of the combustion in a chamber without putting any solid materials in it, the result seems to be good. Now, I am trying to sovle the phase change problem, the solid bulk is exactly the chamber-shape-fitted with several inches thickness. My problem is that I don't know how to set a solid region other than fluid. and furthermore, the difference in grid generation.
Thank you CFD people help me out.
Old   October 14, 1998, 12:41
Default Re: Geometry setup for phase change problem
sheng
First you can do solid region defination based on your old Grid file, put some specific physical properties such as Laminar Viscosity=10 or more big, after the solver running you will see there is almost zero velocity within your solid region. (If you want to do phase change with this solid, you'd better create fine grid in the solid region)
If you want to phase change of this solid, then 2 ways: 1 modlify the solid grid by moving grid method, recreate your grid; 2 keep the old grid, after several time step, redefine the physical properties.
Hope this will help Good luck
Gambit geometry problem cestrin FLUENT 3 July 4, 2012 03:33
Setup of flat plate problem for laminar layer pankos Main CFD Forum 3 August 9, 2011 18:37
[ICEM] [FLUENT] 2D Geometry problem when exporting to Fluent - Unwanted walls MikeTichondrius ANSYS Meshing & Geometry 1 February 9, 2011 14:31
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 05:53
How to setup problem in OpenFOAM devesh.baghel OpenFOAM 2 December 11, 2009 02:27
