Convergence Study
Old   March 24, 2019, 12:07
Default Convergence Study
anonymous
asda3D is on a distinguished road
Hey everyone I am quite new to CFD and I am currently undergoing a project where I am required to carry out a convergence study. I want to make sure that parameters (heat transfer, velocity) are steady within my domain.
I have a questions and that is, does my choice of convergence points in my model have to be located at a node or can it be any point of interest inside the domain?
For example to ensure heat transfer near the wall is steady over several hundred iterations, I can pick my convergence point 5mm away from the wall on a node in my first mesh. Redesigning the mesh to save on computational time, this point no longer is represented by a node. Would this have any impact?
I am a little unsure about this as i believe the whole domain is calculated by interpolation techniques between nodes, so this shouldn't have any impact on my mesh convergence study.
If you have any knowledge you are willing to share much appreciated.
Thank you in advance,
asda3D
asda3D is offline   Reply With Quote
Old   March 24, 2019, 12:42
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
The convergence to the steady state requires that time derivatives in all the computational points tend to vanish. You need to check this condition (numerical time derivatives< threshold) everywhere in the cells.
FMDenaro is offline   Reply With Quote
Old   March 24, 2019, 17:02
anonymous
Thank you for the reply, I do understand that. Overall convergence is easily identifiable on CFD software, however even if the global parameters have converged there are points of interest where the physics of the flow is very disruptive and may not have converged. This is why points of interest need to be accounted for as well.
My questions is, do these specific monitoring points have to be located on the mesh in order to show convergence or is it OK for the points to lie off the mesh. Would this impact the points convergence?
Old   March 24, 2019, 17:26
It makes no sense to use interpolation to monitor points that are not those wherein the equations are numerically solved. If the derivatives in the computational nodes are telling you that the steady state is reached you get the converged solution.
Old   March 25, 2019, 08:36
Eifoehn4's Avatar
Eifoehn4 is on a distinguished road
asda3D
In my opinion it doesn't matter, if all points of your convergence study on different meshes are collocated. Each sampled point in the computational domain is part of the solution, collocated or not. Therefore it shouldn't have any impact on your study.
Eifoehn4 is offline   Reply With Quote
Old   March 25, 2019, 09:18
Lucky
Convergence is not a binary converged/not-converged decision nor is it an objective decision.
There is the direct way of checking that time derivatives is less than a threshold in every cell. There is also the indirect way of checking other calculated parameters (like interpolated values). Then someone makes the subjective value call or whether it is good enough or not.
Grid Convergence Index (GCI) for study involving five grids RobV Visualization & Post-Processing 0 December 30, 2016 07:22
[ANSYS Meshing] Grid convergence study AS_Aero ANSYS Meshing & Geometry 1 June 7, 2013 05:29
[ICEM] Grid Convergence Index study for a hybrid mesh j_h_86 ANSYS Meshing & Geometry 2 December 6, 2012 12:45
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 11:55
convergence/ advise for permeability study CFDnewbie CFX 0 August 21, 2005 03:50
