March 9, 2019, 07:29 |
Steady State solution and Transient solution
Arijit Saha
Rep Power: 7 |
What is the difference between steady state and transient solution?
Based on the application how can I figure out that which solution to use? It will be really helpful if someone helps. |
March 9, 2019, 13:17 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
Steady state solution means you solve the equations with all the time derivatives disregarded from the system. Unsteady solution assume that you want to start from some initial condition and prescribe boundary conditions to simulate a time-dependent fluid dynamics by considering all the time derivatives in the system. Depending on the physics of the problem, the transient solution can or cannot tends towards a steady state. Generally, steady state solution appears at very low Reynolds number as well as for statistical solutions of turbulence (RANS formulations) |
March 10, 2019, 06:40 |
Jayant Kumar
i have a cfd problem setup in which i have to insert a udf for soil temperature distribution with respect to depth and real time as an initial condition. I have the equation for it right now i have insert a constant soil temperature patch., please help in how may i proceed
March 11, 2019, 01:19 |
#4 | |
Arijit Saha
Rep Power: 7 |
I had performed one transient simulation of an airfoil where after a certain time-step the solution converged and it doesn't change velocity(for example) with time, so in this case what can I predict from this solution? And last thing, suppose I have an airfoil at whatever AOA which kind of simulation is perfect is it transient or staedy? |
March 11, 2019, 03:49 |
#5 | |
Rep Power: 73 |
This is not the Fluent section of the forum. However, a convergence to a steady state means that your numerical solution produces all time derivatives vanishing (in practice they are below a threshold value). |
March 11, 2019, 03:52 |
Arijit Saha
Rep Power: 7 |
But in transient at each time-step there should be a convergence between two successive time-step. In general convergence means when the two values of residual converge below tolerance value then why does convergence takes place in transient?
March 11, 2019, 04:02 |
#7 | |
Rep Power: 73 |
Just as example, consider the solution of a linear time-dependent equation using an implicit method. At each time step you have an algebric system to solve. Therefore, you must ensure convergence of the iterative method at each time step. And that must be repeated until the time derivatives vanish. That idea generalizes to the coupled non-linear NSE. |
March 11, 2019, 04:08 |
Arijit Saha
Rep Power: 7 |
I had previously done one transient analysis of airfoil where the transient nature changed into steady after few time-steps. I ve found that the case is quasi-steady where the transient finally changed into steady. So whats the reason behind this? When does this happen generally( in terms of convergence)?
March 11, 2019, 04:41 |
#9 |
Rep Power: 73 |
- Convergence of iterative methods in a time step is a numerical issue.
- Convergence to a steady state is a physical issue and depends on the flow problem. Errors in the numerical setting can alter the physics of the flow problem, for example a too high numerical viscosity can produce a non-physical steady state. A further example can be the non-convergence of the RANS solution caused by a not suitable turbulence model. Your case means nothing without the full details of the simulation |
March 11, 2019, 10:19 |
#10 | |
Lucky
Rep Power: 66 |
It's related to whatever was the transient and how long it takes the transient to disappear. For example, if there was a bug (like the insect) in your simulation running around causing trouble, then the times it takes is how long it takes you to find and kill the bug. If the transient is caused by residual effect of an initialization/initial guess, then it's related to how long it takes for the initial guess to die out. This can mean how long it takes stuff to flow from inlet to outlet. But it also could be shorter. It depends what was the transient. Not all transients are the same transient. |
2way FSi, Initialize with steady solution, Fluent, Transient Sturcural, System Coupli | mmkkeshavarzi | FLUENT | 1 | June 28, 2024 08:03 |
The difference between steady state and transient | JuPa | CFX | 36 | December 9, 2019 23:50 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 06:37 |
Steady state solution ----> transient | nskelly | OpenFOAM Running, Solving & CFD | 4 | March 12, 2018 12:49 |
Steady state solution as an initial condition for a transient problem | adnanakhtar | FLUENT | 7 | November 25, 2016 06:16 |
