How to verify there is turbulence in a flow with a k-epsilon turbulence model
Old   March 7, 2019, 09:14
Default How to verify there is turbulence in a flow with a k-epsilon turbulence model
Maveryck Andres
Maveryck is on a distinguished road
Good day every one,
I have implemented a k-epsilon turbulence model for an incompressible flow solver, and now I want to verify that the results I get correspond to a turbulence regime. By solving the k equation I have the kinetic energy, and the rate of dissipation from the epsilon equation. With those values how could I stimate if the flow is turbulent?
Thanks a lot in advance!
Maveryck is offline   Reply With Quote
Old   March 7, 2019, 09:56
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Originally Posted by Maveryck View Post
Good day every one,
The resulting turbulent viscosity ratio is always a good measure. Yet, in principle, assuming proper bc are given, a RANS turbulent model is not supposed to give non-turbulent results and they are only valid in a fully turbulent regime.
However, you should compare with other k-epsilon implementation if you want to validate the code.
sbaffini is offline   Reply With Quote
Old   March 7, 2019, 11:21
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
As wrote by Paolo, there is no sense in asking if the turbulence exists after you get a RANS solution. It is exactly the opposite, if you have a fully developed turbulence problem in energy equilibrium then the RANS formulation could provide reasonable statistical results.
FMDenaro is offline   Reply With Quote
Old   March 7, 2019, 16:09
Lucky
There is formally no way to tell. The only hint is the eddy/turbulent viscosity which should be 0 for laminar flow and non-zero for turbulent flow. But chances are, you will always have non-zero turbulent viscosity because you are using a turbulence model which assumes the flow is already fully turbulent.
In other words, you should assume that the solution corresponds to the fully turbulent result even if this solution is not accurate. As a corollary, if the real flow is supposed to be laminar, then your simulation corresponds to what the flow would look like if it were turbulent.
Old   March 8, 2019, 04:22
VS
VSass is on a distinguished road
The most reliable indicator is the insight of the physics of each specific case you are working on. Also, validation of your results on simple cases from the literature.
VSass is offline   Reply With Quote
k epsilon
Low Re Turbulence model VS Low Re flow and Turbulence Modelling background pchoopanya Main CFD Forum 4 May 10, 2018 12:05
Choice Turbulence Model Flow around Airfoil kayla1994 Main CFD Forum 3 May 10, 2018 05:28
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Turbulence model for Laminar flow Terry Main CFD Forum 8 August 14, 2010 06:45
validating turbulence model on flow around a car Pedro CFX 1 February 20, 2008 17:32
