Negative pressure in hydroforming process
Old   March 7, 2019, 02:54
Question Negative pressure in hydroforming process
Shahab Khakpour
Shahab Khakpour is on a distinguished road
Hello everyone,
I am going to simulate hydroforming process of a close-end pipe. I need to apply velocity as the inlet and all other surfaces should be considered as the wall. I did it through two approaches: 1- one-way FSI: I solved the fluid model via fluent and linked the solution to the transient structural. I considered the fluid pressure on the wall as the external force for structural analysis and 2- I tested two ways FSI via system-coupling and in both cases, I faced with the same problem:
At the beginning, only the positive pressure exists at the close-end region and all of the tother regions have negative pressure. By keep going, the positive pressure moves toward the inlet, but after 5 mins of simulation, still, one third of the pipe has negative pressure. The negative pressure causes shrinkage of the pipe, while the aim of the hydroforming is inflation of the subject. I think it could be due to that there is not any outlet. I use k-e turbulent model and I have tested multiphase flow, but it did not work.
I would greatly appreciate it if you could help me that.
Shahab Khakpour is offline   Reply With Quote
Old   March 8, 2019, 04:41
VS
VSass is on a distinguished road
What boundary and initial conditions do you apply for the pressure? Does your solver solve for the absolute or relative pressure fields? Mesh specifications are also important.
VSass is offline   Reply With Quote
end-closed pipe, hydroforming, negative pressure
CFX Solver stopped with error when requested for backup during solver running Mfaizan CFX 40 May 13, 2016 07:50
Modeling transient negative pressure (suction pressure) in outlet N_mrtz FLUENT 1 July 18, 2013 21:59
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
negative pressure mAx FLUENT 0 January 25, 2006 15:31
