February 27, 2019, 12:59 |
Heat exchanger design
Abdul
Rep Power: 9 |
Hello everybody,
I am designing a counter flow heat exchanger embedded in a phase change material. I am using corrugated pipes instead of plain ones with fins attached throughout the length of the heat exchanger. It is quite a detailed geometry. I was wondering, normally how do CFD experts model large heat exchangers? Since the whole exchanger would require at least 100-120 million cells to incorporate all the details (about 6*6*6 feet). I cannot use a plane of symmetry since there isn't one, and I am interested in the transient thermal performance. The two options I had in mind are as follows, but im not sure if they would work: 1. Scaling down the model by e.g. a factor of 10 (but this would result in the same element numbers of the mesh just with smaller sizes). Dont know if it is effective ? 2. Doing only a portion of the exchanger (but no sure which portion to do, since every length in the exchanger would have a different temperature and heat profile). Then somehow finding the thermal parameters per unit length and extrapolating ? Do I have any other reasonable scientific option ? Looking forward to your advice, based on your experience for such problems. Thanks Abdur |
February 28, 2019, 13:07 |
Abdul
Rep Power: 9 |
please help !!
Define a Counterflow heat exchanger in FloEFD | Kylbalsam | FloEFD, FloWorks & FloTHERM | 1 | August 16, 2016 09:46 |
Double pipe heat exchanger | mohcin | FLUENT | 21 | June 18, 2016 15:19 |
Solidwork flow floefd - modeling heat exchanger in a system | mzreik | FloEFD, FloWorks & FloTHERM | 3 | January 8, 2016 12:30 |
Ansys Fluent analysis of heat exchanger | MStudent | FLUENT | 2 | April 20, 2015 09:40 |
Simulation flow loop of Heat exchanger | lalolala | FLUENT | 1 | November 22, 2012 00:53 |
