March 4, 2019, 14:32 |
#21 |
Filippo Maria Denaro
Rep Power: 73 |
Sec. 6.4.3 in the Pope textbook addresses that. Eq.(6.158)-(6.159) shows that the transform of the autocorrelation is nothing else that equivalent to the Fourier transform of the kinetic energy. Of course you should see the hypothesis in terms of isotropy and homogeneity to do that.
May 9, 2021, 06:19 |
#22 |
Rep Power: 5 |
Dear community,
let me stick to this thread since I don’t want to create another one called “(…) spectrum”. Btw, I think that if there are so many threads devoted to this problem it clearly means that it is not easy to understand, indeed I have hard time to apply the “spectrum” concepts in more practically relevant fluid mechanics problem that I encountered. From my understanding the characteristic scales in turbulent flow are applicable to the isotropic turbulence. However, in many cases when the Re is not sufficiently high there is no isotropic turbulence anywhere in the jet, but still authors introduce estimated length scales from their experiments. My goal is to quantify the characteristic length scales appearing in my parametric LES simulations of the jet flows. I have some questions related to that problem: 1. Using the route introduced earlier under this thread we obtained transform of autocorrelation. Can it be inversed to obtain autocorrelation function in the physical space readily usable for calculating, i.e., integral length scale (integral from zero to infinity from the autocorrelation function)? 2. How to find out what is the highest physically correct frequency (lowest) length scale that is representable (physically consistent) on the spectrum from LES simulation in which filtering is introduced implicitly by discretization method? Is the bandwidth limited by the spatial resolution or time resolution or it depends on something else? Let say, my mesh dx=1e-3 m and time step dt=1e-5 s, then the maximum frequency is 100 000 1/s and maximum wavenumber 1000 1/m, both devided by 2? 3. Is this true: “to measure some dominant frequency at some spatial location I only need a time signal from that location but to measure the characteristic length scale I need many signals from spatially distributed probes at a specific time instant”. If not true could you please explain why? I myself and probably many other users would be grateful for your comments on one or more points from the above list of questions. |
May 9, 2021, 06:56 |
#23 |
Rep Power: 73 |
Such a discussion is indeed already addressed elsewhere.
First of all, to give a rude route, the spectral analysis can be performed also in one single spatial direction, provided that the flow is homogeneous in this direction. For example if you have a single jet in a domain you could perform a spectral analysis in spanwise direction assuming periodicity (that is a series of jets). Lenght scale can be determined by correlation. In regards of LES analysis, you have several aspects. The LES grid introduced the max representable frequency kNyquist=pi/h (in your case is 1000*pi). But, depending on the shape of the filter (smooth or not), the physical representation of the energy content at frequencies close to kNyquist can be affected by the filtering. In any case the filter should lie before the dissipative range, that is in the LES solution you cannot represent the Taylor microscale as well as, of course, the Kolmogorov one, |
June 17, 2021, 13:53 |
#24 |
Rep Power: 5 |
June 17, 2021, 14:03 |
#25 |
Rep Power: 73 |
June 17, 2021, 14:09 |
#26 |
Rep Power: 5 |
Dear Sir,
my signal is 0.028704 s long and is composed of 16384 data points. This gives 1/(2*dt) = 285 395 Hz Regards |
June 17, 2021, 14:27 |
#27 |
Rep Power: 73 |
June 17, 2021, 15:33 |
#28 |
Rep Power: 5 |
Please correct me if I am wrong, I think you refer to the angular frequency omega=2*pi*f [rad/s] (not the regular one Hz) which max for my case is omega_max=2*pi*f_max=2*pi*(n_data/T)=2*pi*(16384/0.028704)=3.586e6 [rad/s], so the Nyquist (angular) frequency is indeed omega_max/2=1.793e6 [rad/s].
Why not to express the frequency domain using regular frequency with f_max=1/dt (Hz) where f_Nyq=1/(2*dt)? |
June 17, 2021, 15:41 |
#29 |
Rep Power: 5 |
I need to add one more remark. If I scale my PSD frequency axis as it is to express it in Strouhal number I get the peak at St=0.6 (or at f=1000Hz with regards to my current PSD plot) which physically corresponds to the dominant frequency of the “coherent” vortices merging which gives the peak in turbulence intensity plot as my probe is located almost exactly at the end of the potential core of the jet.
June 17, 2021, 15:47 |
#30 | |
Rep Power: 73 |
I consider the cut-off frequency due to a sampling of a signal (space or time is not relevant). That is in your case f(t) = Sum Fk(t)*exp(i*k*t) being k=n*2*pi/T the frequency. being T=N*dt, hence k= n*2*pi/(N*dt) nmax is the max wavenumber you get from the ratio between the largest wavelenght lambdamax and the smallest wavelenght lambdamin->T/(2*dt)=N/2. Thus kmax= nmax*2*pi/(N*dt)= (N/2)*2*pi/(N*dt) = pi/dt Have a look here for more details https://www.researchgate.net/publica...ing_a_function |
June 17, 2021, 16:36 |
#31 |
Rep Power: 5 |
Thank you Professor for the notes and your time. I must have missed some important concept behind FT and I need to reconsider this once again slowly. My biggest issue is that I don’t really understand why to show a PSD as a function of an angular frequency (pi/dt [rad/s]).
Since Xi is arbitrary, why not to say Xi is an ordinary frequency [Hz]? Nyquist frequency in “your” and “my” definitions differs by a scaling factor 2*pi. I don’t know why it needs to be employed. I have read your notes and see clearly that you expressed the frequency in terms of radians per s or m. In your notes q_max=L/(2dx) have almost the same meaning that f_nyq=1/(2*dt), since L in q_max cancels out with L in expression for k_max. I will think about this I don’t want to bother you too much. Thank you once again for your time. |
June 17, 2021, 17:04 |
#32 | |
Rep Power: 73 |
The key is in case of assuming the period to be T=2*pi. In a non-dimensional form you have T=1. Indeed if you compare your definition 1/(2*dt) to my definition (pi/dt) you understand you are considering half-period =1/2 while I have half period = pi. On the other hand the Fourier series is clearly represented with the basis exp(i*k*x) = cos(n*2*pi*x/L)+i*sin(n*2*pi*x/L) https://en.wikipedia.org/wiki/Fourier_series |
June 18, 2021, 06:25 |
#33 |
Rep Power: 73 |
A similar analysis is detailed in the Anderson's textbook, you can read it at page 156.
The expression you use 1/(2*dt) is also reported in literature but you should see the whole picture of the discussion. If the exp(i*kn*t) is expressed as cos(kn*t)+i*sin(kn*t) one should check if t is dimensional or not. If it is dimensional then kn is dimensionally a 1/time term. If the period is a general T (s) value (as happens in your problem), the periodicity of the sin/cos functions is expressed for kn=n*2*pi/T (Hz), n being the wavenumber. Some cases as examples: - If were T= 2*pi (s) you get kn=n (Hz) and, as nmax=N/2 (N the numbers of time step dt (s), that is T=N*dt=2*pi (s)), you get knmax=nmax=N/2= (pi/dt) (Hz) - If were T= 1 (s) you get kn=n*2pi (Hz) and, as nmax=N/2 (N the numbers of time step dt, that is T=N*dt=1s), you get knmax= (N/2)*2*pi = pi/dt = pi/dt(Hz) Conversely, if the analysis is for a non-dimensional sample, it is assumed that the non-dimensional period is Tad=T/Tr=1=N*dtad, knad=kn/kr (subscript r is a reference value) and hence: knad*kr=n*2*pi/(Tad*Tr) and assuming kr=2*pi/Tr you have knad=n/Tad=n Now you have nmax=N/2 and (knad)max=N/2=1/(2*dtad) that is your expression. This is what I can think of in order to make congruent your definition and my definition. I don't know if some different theoretical analysis could be done. |
June 24, 2021, 11:38 |
#34 |
John Walker
It's a very complicated topic.
ball marker tool |
April 8, 2022, 20:40 |
power Spectral Density
#35 |
Tarek Hadj Hassen
Rep Power: 4 |
Hi All,
I try to draw the power spectral density of a time series in order to compare it with the theoretical one. The problem is the density value calculated by this script was divided by 1000. Please can any one check the script ? This is the link of time series txt file : https://drive.google.com/file/d/1QMc...ew?usp=sharing Code:
#FFT Analysis time=elevation[200:11070,0] H=elevation[200:11070,1] tfd=np.fft.fft(H) fft_freq=np.fft.fftfreq(N,time[1]-time[0]) #Power spectral density PSD=tfd * np.conj(tfd)/np.square(N) plt.plot(fft_freq,PSD) plt.xlim(0,0.4) #plt.title('spectral density') plt.xlabel('frequency,f,[Hz]') plt.ylabel('Spectral density [m**2 s]') plt.show() |
Energy spectrum-wrong spectrum shape | huangxianbei | Main CFD Forum | 20 | June 9, 2024 06:03 |
power spectrum density | hosseini | CFX | 1 | August 31, 2017 08:43 |
turbulent energy spectrum problem | cfd.newbie | Main CFD Forum | 6 | September 24, 2015 17:13 |
3D Energy Spectrum | CFDrookie | Main CFD Forum | 3 | September 23, 2015 11:16 |
turbulent energy spectrum | cfd.newbie | FLUENT | 0 | June 18, 2008 19:34 |
