dimentionless velocity expression POST CFD
Old   February 27, 2019, 07:11
Default dimentionless velocity expression POST CFD
Odonata is on a distinguished road
I analyse rotatory flow in a tank (R=100mm). I was asked to present velocity change along the radius as a dimensionless velocity (non-dimensional velocity). I plot velocities at 4 mm above the bottom.
I struggle to write the expression in post cfd to plot the expression in the program.
Can anyone provide any step by step instruction?
Also I wonder if the dimensionless velocity will be valid along the radius, after all it is a near-wall phenomena.
Big thanks!
Odonata is offline   Reply With Quote
cfd post, cfx, friction velocity, non-dimensional velocity
Using CFD Post for OpenFoam results Karpfen OpenFOAM Post-Processing 3 January 19, 2018 09:48
Defined inlet velocity is different with inlet velocity on CFX post jonpewpew CFX 2 November 2, 2017 17:40
CFD Post - How to check for case in an expression pilakin ANSYS 0 September 26, 2014 05:44
Parallel process & CFD POST jypark FLUENT 2 August 15, 2013 00:49
CFD Post Expression over time chart (without monitor point) Badi CFX 1 July 17, 2013 18:22
