February 21, 2019, 05:45 |
Multiple cell zones or single cell zone?
International
Hi everyone.
I'm beginner with Ansys fluent and I've to do a 3D solar load simulation (DO radiation e solar ray tracing) on a building. The buildings materials are: concrete for roof and walls, the glass and the ground material. Should I have to do different cell zones for each material? Can I set only the air as a cell zone and put the wall, roof, glass as a Boundary condition? In the attachment 1 the green one is the fluid domain; the violet one the ground; In the attachment 2 the green one is the concrete material, in violet the ground and in blue the glass. I hope someone can help me, thanks! |
September 8, 2019, 03:06 |
Cell zones
Emmanuel Sansusthy Tardío
If you are only interested in studying the fluid (air) inside the building, you can assign cell zone just to that volume.
About the walls, windows, and others, you can keep them as coupled walls (shells or surfaces) to enable heat transfer. Additionally, if you want to take into account the heat conduction through them, enable "shell conduction" in the wall boundary conditions. There, you specify the thickness of the walls or windows and the material, which will supply the thermal conductivity. You can even make multi-layer walls with this option. |
ansys fluent 19.2, boundaries condition, cell zone conditions, do radiation, solar load model |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 12:32 |
[mesh manipulation] refineMesh Error | mohsen.boojari | OpenFOAM Meshing & Mesh Conversion | 3 | March 1, 2018 23:07 |
[ICEM] 2D, Defining multiple Cell Zones | jchan033 | ANSYS Meshing & Geometry | 1 | February 12, 2017 13:31 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 13:11 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
