Aeroacoustics Scaling laws
Old   February 19, 2019, 10:21
Default Aeroacoustics Scaling laws
AS_Aero is on a distinguished road
Hi
Is there anybody having experience in scaling laws for Aeroacoustics ?
I have to do some aeroacoustics simulation for huge piping system of 2.5m diameter and different bends and pipe lenghts of 100m. (its like a huge industrial hvac system ) and now I want to measure the noise generated from it and noise sources etc. But firstly I want to know if I can scale down the entire system from meters to centimeter so that I can do the simulation with reduced computational power. And then in the case of Acoustics I will need some scaling law as well. So I am not sure if there is any possibility for that as well.
Kindly let me know if anyone has experience in that.
AS_Aero is offline   Reply With Quote
Old   February 19, 2019, 13:53
Lucky
Geometry scaling will not save you any computational cost. To save computational cost, you have to reduce the actual size of the problem and/or reduce complexity (less equations, etc).
The flow stuff scales like Reynolds number and mach number. The acoustics stuff scales like Helmholtz number. For these difficulties, industry people say acoustics is unscalable.
Old   February 20, 2019, 08:07
Dear Lucky Tran
Thanks a lot for your reply.
Old   February 20, 2019, 14:42
Lucky
And in case it was not obvious, you can also just use a coarser mesh with fewer cells. The number of cells and number of equations is what determines computational cost. It doesn't matter whether these cells are 1 pm, 1nm, 1mm, 1m, 1km, or 1AU in size.
OPENFOAM for Aeroacoustics simulations (using Linearized Euler Equations) ms518 OpenFOAM 6 February 21, 2021 17:49
Scaling Airfoil morteza08 Main CFD Forum 1 November 9, 2015 01:44
Global scaling - grid independency testing Jenny CFX 6 December 10, 2013 04:52
aeroacoustics Constantinos Main CFD Forum 1 March 22, 2004 14:32
Aeroacoustics - Flow over Cylinder Axel Rohde Main CFD Forum 2 August 17, 2002 13:18
