February 15, 2019, 12:05 |
Vorticity thickness in temporal mixing layer
Rep Power: 8 |
Hi!
I am struggling with calculating the vorticity thickness in temporal mixing layers. Which is defined as Where U_1 and U:2 are the lower and upper free stream velocities in opposite directions. A typical nondimensionalized velocity profile is U/U_1=tanh(y). To demonstrate the problem: A simple example is if U_1=1 and U_2=-1. The maximum gradient of tanh(y) is 1. Which yileds a vorticity thickness of 2. But I am supposed to get vorticity thickness of order 1e-4, based on a couple of papers, what am I doing wrong? |
February 15, 2019, 12:07 |
Rep Power: 8 |
Vorticity thickness =(U_1-U_2) / (du/dy)_max
February 15, 2019, 12:31 |
Filippo Maria Denaro
Rep Power: 73 |
Are you working with dimensional or non-dimensional variables? The Reynolds number has the vorticity thickness as characteristic lenght, therefore in non-dimensional variables this thickness is O(1). |
February 15, 2019, 12:47 |
#4 | |
Rep Power: 8 |
Dimensional. For example, one paper claims to have vorticity Reynolds number of 100 with 0.2 mach, which for air is about 70 m/s. which gives a vorticity thickness of 140/70 which is 2. In order to fulfill reynolds number of 100 the viscosity has to be 0.35 which doesn't make any sense. 100=((U_1-U_2)*d)/vis vis=100/(140*2)=0.35 where d is viscosity thickness. |
February 15, 2019, 12:50 |
#5 | |
Rep Power: 73 |
vorticity thickness of 2 meters???? |
February 15, 2019, 12:59 |
Rep Power: 8 |
February 15, 2019, 13:20 |
#7 | |
Rep Power: 73 |
If you consider that U1=1m/s and U2=-1m/s and the initial velocity is u(y)= U1 * tan h (2*y/delta1) the derivative is du/dy = 2*U1 / (delta1 *cos h (2*y/delta1)) Therefore the delta1 value is the initial condition you have to prescribe. We did that in Sec.5.2.1 https://www.researchgate.net/publica...-uniform_grids |
February 15, 2019, 13:36 |
#8 | |
Rep Power: 8 |
Thank you, but what if the delta is the vorticity thickness? Which looks like the paper I read did? |
February 15, 2019, 13:41 |
#9 | |
Rep Power: 73 |
But the vorticity thickness evolves starting from some initial condition... If you are interested in the temporal mixing you have to consider the evolution delta(t) but the thickness at t=0 is what you prescribe from your initial velocity profile |
February 15, 2019, 13:47 |
#10 |
Rep Power: 8 |
Ok thanks, so that means I can just reverse the calculations in order to find out what initial delta1 they used ?
February 15, 2019, 14:51 |
#11 |
Rep Power: 73 |
February 15, 2019, 18:22 |
#12 |
Rep Power: 8 |
February 15, 2019, 18:28 |
#13 |
Rep Power: 73 |
February 17, 2019, 11:36 |
#14 |
Rep Power: 8 |
Thank you
[snappyHexMesh] SnappyHexMesh - no layer added | bejbro | OpenFOAM Meshing & Mesh Conversion | 5 | February 1, 2020 21:05 |
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner | panpanzhong | OpenFOAM Meshing & Mesh Conversion | 5 | July 3, 2018 06:53 |
[snappyHexMesh] Problem airfoil snappyhexmesh add layer | bye bye my blue | OpenFOAM Meshing & Mesh Conversion | 1 | May 5, 2017 06:56 |
[snappyHexMesh] SnappyHexMesh: Layer on corners | Pj. | OpenFOAM Meshing & Mesh Conversion | 9 | July 17, 2014 05:26 |
boundary layer thickness | 98.4F | Main CFD Forum | 1 | December 29, 2000 08:23 |
