Inversion of the prandtl-meyer relation + Supersonic expansion |
February 12, 2019, 15:02 |
K
Rep Power: 9 |
I am working on the design of supersonic nozzles and I am using the method of characteristics. In this method, we should find the Mach number by inversion of the of the Prandtle-Meyer relation. For low Mach number, one can use the Newton-Raphson method. and for air, there is the very well know receipt of : Hall, I. M. "Inversion of the prandtl-meyer relation." Aeronautical Journal 79 (1975): 417. In my case, I have high Mach numbers. So, if I use Newton-Raphson, the residual is very high. And I treat a case with CO2 molecules and therefore gamma different from 1.4. My search through internet was not successful. I am wondering if one supersonic expert could help me with that. Thanks in advance |
February 12, 2019, 15:16 |
Filippo Maria Denaro
Rep Power: 73 |
Please, provide details about what are you doing in solving numerically the equation for determining the angle
February 13, 2019, 04:30 |
#3 | |
K
Rep Power: 9 |
I want to find the Mach number through a known angle (nu) with respect to which the flow turns isentropically. Please find the prandtl-meyer in the attached file. This relation gives nu as a function of Mach number. What I want is to find Mach number for a given angle nu. This implies to inverse the above equation. I know two methods. First: We can do it by using the Hall relation. However, hall relation is for gamma equal to 1.4. Second, doing Newton-Raphson where residual is very high for me (high mach number and low gamma) and I dont reach convergence by the mentioned method. So, I am wondering if there are other methods which can give me Mach number as a function of nu. I looked if there is analytical expressions, I did not find any thing for gamma equal to 1.29. Or even tabulated table would be nice. But my search was not successful. Do you have any suggestion ? |
February 13, 2019, 04:44 |
Rep Power: 73 |
And does your fixed angle fulfill the max deviation limit?
February 13, 2019, 05:54 |
K
Rep Power: 9 |
Yes, and lets say that this equation is not aware of the fact that there is a maximum deviation fixed by tetha maximum at the diverging part of the sharp nozzle and should find a Mach number for a given nu, whatever is the value of nu. |
February 13, 2019, 06:09 |
Rep Power: 73 |
Have you plotted the function along the Mach number to see it graphically?
February 13, 2019, 06:34 |
#7 | |
K
Rep Power: 9 |
I know the trend should be something like the photo being attached. Do you suggest me to make a tabulated table and use the table afterwards to identify a Mach number for a given nu ? |
inversion, method of characteristics, prandtl-meyer function, supersonic nozzle |
[blockMesh] Create internal faces as patch in blockMesh | m.delta68 | OpenFOAM Meshing & Mesh Conversion | 14 | July 12, 2018 15:43 |
fvOptions | npatricia | OpenFOAM | 6 | May 23, 2018 06:21 |
Supersonic flow over an airfoil. FLUENT Lift don't match up with Shock Expansion Tech | enriccasas | FLUENT | 1 | August 21, 2013 07:43 |
Best CFX settings for supersonic free expansion [CFX] ? | nav_5 | CFX | 0 | August 30, 2012 07:17 |
Supersonic expansion | aap | OpenFOAM Running, Solving & CFD | 3 | February 22, 2008 04:29 |
